  New Posts New Posts RSS Feed - Removing Brake Booster - 76 Gran Torino
torinomike650 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Topic: Removing Brake Booster - 76 Gran Torino
    Posted: 08-May-2019 at 8:12AM
I removed the 4 nuts on the inside firewall, does anyone know what kind of clip/bolt/fastener is holding the booster to the brake pedal and how best to remove it?
I am 6'4" and have a hard time getting my head under there to have a good look at it, so anyone with experience removing the booster from these cars that have input, I would greatly appreciate it. Thanks!
1976 Ford Gran Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2019 at 4:24PM
mike its a wire clip that slides on through a hole in the center of the pivot shaft, just slide it off and move the booster rod and brake switch to the side and off the pivot shaft
