  New Posts New Posts RSS Feed - Ricks 72GTS
Ricks 72GTS
 Post Reply Post Reply Page  <1 8910
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 7:22AM
I wonder why the pic turns when posted
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 9:12AM
Can I cut the springs with a sawsall?
sj_mr2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sj_mr2 Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 10:06AM
you can cut them with anything except a torch
Clayton
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 11:06AM
Angle grinder with cutoff wheel is the quickest (non-torch) way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 12:57PM
Great thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 1:42PM
I agree, angle grinder with a cut off wheel is the easiest and quickest way.  I have also used a band saw.  I'd think a reciprocating saw would be tricky to get a nice cut.
That pic you posted that came out sideways.  Did you take it with a phone by chance?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 1:51PM
Yup. Android phone
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 1:54PM
I have run into this issue with cell phone pics on other sites.  For some reason it defaults the picture to sit in one direction.  I will play around with the settings and see what I can do.
BTW, I think you should be good with 1/2 coil cut.  I have been compiling info on the spring thread and trying to collect pics and it seems 1/2 coil works for most cars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 16-January-2018 at 2:19PM
Your car is pretty much the same as mine. I love the look. Only difference 400 and 351c... If it sits a tad lower I'm ok with that
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:07AM
I cut 1/2 coil out of my front coils, progressive rate rears, so I could not cut them. I like it ok, but really wish I'd cut a full coil out and gone with a shorter rear coil. With 17 inch wheels it looks good, but wanted a lower look. Tires are 235/55-17 and 275/55-17. This is with a 460 and C6, so a 351/400 would sit higher.
Edited by unlovedford - Yesterday at 12:08AM
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:27AM
That looks good
Those are the 80090 moog up front?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 40 minutes ago at 10:48AM
As for the suspension parts did you guys paint them? Will they start to surface rust if I don't. I clear coated my master cylinder because I liked the natural look but it is starting to turn that ugly rusty orange. I'm going to just spray it black. Should I do the same with the suspension parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 15 minutes ago at 1:13PM
I had all my parts blasted and powder coated.  I didn't powder coated my spindles or caliper brackets, just painted them.  I used some of Eastwoods products to paint the stuff that was natural steel coloured from the factory, the strut rods for example.
Factory finish on the arms was half black, half bare metal, with the inner part being painted, outer half bare.  Some people replicate this with paint, I just powder coated my arms all black.  You can see the finishes I did in this photo:
If you going this far, at minimum wire wheel and paint all the parts with a decent quality paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 47 minutes ago at 1:41AM
Great pic. Thanks Again
