roof swap |
Author | ||
Hooter
New Member Joined: 04-October-2016 Location: Louisville, Ky Status: Offline Points: 18 |
Posted: 13-November-2016 at 9:34AM |
has anyone tried swapping roofs from formal to a fastback
Hooter
kychevyguy
Sounds like a lot of work.
JT, USAF Ret./Architect
TV 2M8O
I had to put a new skin on my formal and there were I'd bet 300 spot welds holding that piece on... and I'm sure the inner structure would need to be changed to go from formal to sportsroof, which means the quarters would have to come off. DEFINITELY A TON OF WORK
unlovedford
Besides the 1/4 panels and roof having to be removed (and swapped), you will need new door, rear and 1/4 side glass and the Formal cars had a structural brace in the trunk on either side that the Sportroofs did not. Also you would need the Sportroof window channel and roof trim. It is doable, but an immense amount of work.
jversch
Senior Member Joined: 25-March-2013 Location: Canandaigua NY Status: Offline Points: 324 |
Be better to just find a fastback .
Jerry VerSchneider
1972 Gran torino formal roof H Code 1973 Gran torino fast back H code. |
embrace the Formal roof, sometimes i think they look tougher than the Sportsroof anyways the Formal roof can look Lean & Mean where the Fastback can look like it's got too much junk in the trunk if you know what i mean?
Edited by Rockatansky - 22-November-2016 at 12:05PM |
Fastbacks look wrong jacked up in the back.
Go Formal!!!!
Torino_Chris
Member Joined: 19-July-2016 Location: Germany Status: Offline Points: 120 |
Would you people stop badmouthing my car?
Just kidding
Regul8r 2
Admin Group Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
NOT worth the time and effort.
If a Sport Roof is what you want, there are PLENTY out there to buy. I have done roof replacements and let me tell you, IT IS NOT FUN!! As said in other posts... you will need so many parts from a sport roof and so much work that you will need a GOOD sport roof as a donor. At that point... just build the sport roof. IF you say you are doing it because of the lack of funds or you have both cars already... DON'T. Truth is you are fooling yourself, you will spend FAR MORE MONEY doing the swap than just buying and building a Sport. If you are doing it to save money, NOPE! You will spend FAR more and be YEARS to complete IF you even got it done. EVERYTHING from the scallop line on the quarters UP is different. Different trunk angle, different upper quarters all the back to the end of the car, different support structures over the wheel wells, different rear package tray, different windows (ALL OF THEM), different interior panels, different trim etc... Basically you would have to cut a formal just past the A-Pillar and at the scallop body line starting at the door jamb back to the rear filler panel behind the bumper and do the same on the sport then swap... the work... FUTILE. |
Owner- www.CaNDeCustoms.com |
yeah wow, i forgot about the glass too, and the unobtainium seals between the windows and the corner on the 1/4 panel haha i might even have those in a box somewhere
Edited by Rockatansky - 24-November-2016 at 6:46AM |
Hooter
I se and understand all of your suggestions the formal roof is a donor because have no title and sportroof needs new floors from firewall back looked easier to cut and swap roof haha.after weeks of looking easier jus to swap floor thanks for help
Hooter
Regul8r 2
So, you have the title for the Sport Roof? if that is the case and the formal has good floors HELL YEAH swap the floors is WAY easier! A whole lot more forgiving and less need to be PERFECT. |
