runing |
mattman
New Member Joined: 26-January-2020 Location: Roxboro, North Status: Offline Points: 3 |
Posted: 19-July-2020 at 3:40AM |
My 1970 Torino GT Convertible 351C with automatic,I crank it up let it run for a minute and as soon as I push the brake pedal it cuts off just like I turned the switch off and have tried to put in gear yet.
MATTMAN
mkshelton
Senior Member Joined: 14-March-2012 Location: Sierra Vista Status: Offline Points: 357 |
Most likely you have a vacuum leak. You can try the starter fluid trick. Just lightly spray along your vac hoses and carefully around the carburetor while listening for changes in idle speed.
yep, or the booster leaking vacuum internally???
