running like crap |
fordpower
Senior Member Joined: 02-September-2010 Location: willseyville,ny Status: Online Points: 1766 |
Posted: 18-August-2015 at 9:19AM |
I have not done anything yet. Car seems to run ok until you try to accerate it then dies and backfires through carb.
Motorcraft 2150 2-bbl???
antlerfiend
Accelerator pump in carb, points or advance not working in your distributor.
^^^ X2 a few more details would help
fordpower
Yes on the carb.Car also has vapor locked ever since KY.
Has the car been sitting? Ethanol in gas goes bad or absorbs water which settles in bottom of the tank. this makes fuel mix lean. Also check for dirt in carb, accelerator pump or power valve, fuel filter/sock at tank. Make sure vacuum advance is plugged in (hoses connected at both ends) Cap and rotor contacts clean and uncorroded.
fordpower
No on the sitting but kids took it around the lake last mo. and filled it back up.That's when it went from poor to real bad.Thinking bad gas myself.I,ll start to play with it tomorrow some.
You should be able to disconnect the fuel line by the tank (rubber to steel connection) and let some of the gas gravity bleed out into a glass jar. Look for separation into layers. (Or, orange gas.)
If you are getting separation, best answer is drain and fill with good gas.
robot9000
Senior Member Joined: 02-September-2011 Location: Michigan Status: Offline Points: 505 |
Carb rebuild. You can get the kit for next to nothing and its hour tops to do.
aquartlow
Kids didn't put in E85 by mistake did they? I ask due to having one family member filling up a gasoline car with diesel and another member filling up a diesel truck with gas . The car ran and smoked like hell, luckily the truck was never started.
oh i'll bet it smoked like hell!! but it will clean all the carbon out of the engine!!! yeah i know this for a fact
aquartlow
Yes, it did! Smoked like a mosquito fogging truck, but ran & sounded like a pulp-wood truck. It was a brand new Lincoln LSC back in '85, my mom was to blame. My father drained the tank as best he could then went and bought 105 "race gas" at the pump to fill it up.
robot9000
E85 would not cause the backfire or stalling. You got a carb with bad acc pump and dirty jets, me thinks
aquartlow
From research that I searched a few months back, using E85 can cause a too lean condition due to the carb's build parameters were in place to meter the stoichiometric ratio of gasoline=14.7, whereas E85's stoich= 9.7 AFR. You would need to richen the fuel metering by at least 51-52% just to compensate. Hopefully something as simple as a bad acc pump, faulty power valve and/or jets is the culprit, just as you mentioned.
antlerfiend
Never rule out the advance on the distributor. I did in Bristol! It cost me alit of racing!
fordpower
Ya not e85 we don't have it yet.Probably carb should go 4b.
fordpower
Went to start on car problem yesterday.As I started to remove plug wires I noticed no 4 not on tight almost off. no 2 the same pushed back on and it was much better no dying and backfiring.Still vap locks though.The carb is bad.
what I do is run the spark plug wire boot up the wire a good ways, then plug the wire into the cap. you should feel it click nice, then slide the boot to the cap tower while holding the wire down into the cap =============== vapor lock is not a carb problem, more a fuel pump pressure issuelack of pressure in the fuel line to the carb allows the fuel to vaporize and the carb receives fumes rather than liquid =============== "90% of all carb problems are electrical" ~ Henry Ford do you have a points distributor? I've fixed a lot of carb problems with a new set of points, better yet a points eliminator module - done
Edited by Rockatansky - 30-August-2015 at 5:40AM |
fordpower
79 electric dist.What it does is after driving a while .Stop for gas or what ever and it will not turn over or just turn over you can hold it to the floor or wait 10min and it turns over easy and starts. Was told its vapor locking .By the way still have that front nose for 77-79.
So, car runs ok until you stop, then needs to cool before restarting. (starter can barely turn engine).
Look for a bad connection (starter cable or ground) or a bad starter with a heat soak issue. Vapor lock will turn over normally, but no start due to no fuel. This is assuming you are not overheating or low on coolant.
by 'won't turn over' do you mean the starter is cranking but it the engine won't fire?
or the starter doesn't crank the engine at all?
so if you hold it to the floor and it starts? it may not be a vapor lock, it could be "boiling over" in the carb and flooding it, phenolic spacer should help with that, i had a couple of my cars do that...so far that plastic spacer has helped
fordpower
starter just barely turns it over like its seized up.This all came about after I removed all the smog junk.Will look into another spacer.
