  New Posts New Posts RSS Feed - RWHP  ?
RWHP ?
gaardbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gaardbo Quote  Post ReplyReply Direct Link To This Post Topic: RWHP ?
    Posted: 15-July-2011 at 3:58AM
SmileNew rebuild 351c, street engine
Hi.
How much hp can i espect at the wheels.
INTAKE: EDELBROCK PERFORMER 4V WITH 2" OPEN SPACER.
HEADS: 4V CLOSE CAMBER 62cc, WITH UNDERCUT VALVES.
10.3 COMPRESSION.
CAMSHAFT: LUNATI BM II 224/234 .536/.562 LIFT.
CARBURETOR: DEMON 625CMF VAC.
PISTONS: FLATTOP WITH CROMMOLY RINGS.
ROCKERARMS: 1.73.
IGNITION: MSD PRO BILLET
FLOWTECH: HEADERS 3"
EXHAUST: 3" WITH FLOW MASTER 40.
CONVERTER TCI STREET FIGTHER 3500 STALL.
C6 TRANNY WITH MANUL VALVEBODY.
9" REAR, 3.25 GEAR, WITH POWERTRAX.
Sory if my english is bad....
kenneth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenneth Quote  Post ReplyReply Direct Link To This Post Posted: 20-July-2011 at 11:58AM
That’s a real hard call.
So many other variables to factor in e.g. – mechanical fuel pump or electric,  roller rockers or STD, power steering, air con etc etc etc, the list can go on and on and even when all is posted it would still be a very hard call to estimated HP rating. The only true way to find out would be to dyno her.
Still it sound like a solid combination you have there.
Any pictures or video to post so we can dribble over them ????
1973 Q code sports roof
Post Options Post Options   Thanks (0) Thanks(0)   Quote gaardbo Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2011 at 7:55AM
HI.
mechanical fuel pump.
Std rockers arms 1,73.
Power steering.
and no fan on the wather pumpe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenneth Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2011 at 9:52AM
The only comparison I could make would be something like this - http://cgi.ebay.com/ebaymotors/FORD-351C-445HP-CRATE-ENGINE-TUFF-DAWG-ENGINES-_W0QQcmdZViewItemQQhashZitem2565eaa072QQitemZ160623665266QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories but bear in mind the HP rating is at the fly wheel and you will lose approximately %15 through the drive train. Again there is no true way of telling unless she is placed on the  dyno
