  New Posts New Posts RSS Feed - Sending unit help
Sending unit help
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Topic: Sending unit help
    Posted: 24-May-2017 at 4:25PM
Has anyone used a sending unit from Dearborn classics? I put one in put 8 gala in the tank and it shows 1/8 tank. Could this possibly be right I haven't filled it all the way yet?
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2017 at 4:58PM
I know this isn't any help but.... When I put a new tank and sender in the 75, the sender reads empty after 16-17 gallons even though it's a 26 gallon tank. That's pretty close to what you're seeing with 8 gallons in the tank. There's definitely something up with some of these senders.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2017 at 6:06PM
probably calibrated in the wrong resistance range of ohms!!!Wink
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2017 at 11:55PM
From what I have heard and/or read, the newer  senders do not have the same ohm resistance within the same sweep of the float arm as compared to the original senders. I had/have the same issue, I tweaked (bent) my float arm to "better" suit my dash's fuel gauge readings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2017 at 3:21AM
I bent it a little but I don't want to screw it up.
