  New Posts New Posts RSS Feed - S&H transmission change
302ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 11-March-2013 at 4:27PM
Sorry, I have been away from this forum for the past little bit. I did use the entire pedal setup out of an sn95 mustang. If I can remember the bolt holes lined up fairly close for the most part. Which I didn't care too much as I reinforced the firewall a bit while I was at it and used the sn95 cobra booster and master as well.
For those interested I'll see if I can dig up a few pics. I also attached the "pedal box" to the steering column like factory for additional reinforcement. The added stress of a heavy cable clutch will flex the factory firewall quite a bit if you don't.
Here is a few I can quickly share.
Finished in the car
Factory look.
I have some more.... I just have to remember where I put them..,
79 LTD II 408/TKO/3.7's
12.52 116.5mph. street tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2013 at 1:43AM
Oh my. I didn't realize it all fit together that clean
