  New Posts New Posts RSS Feed - SOME HELP PLEASE!!
SOME HELP PLEASE!!
KingMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingMe Quote  Post ReplyReply Direct Link To This Post Topic: SOME HELP PLEASE!!
    Posted: 07-October-2017 at 12:44PM
starting a new project and the first thing I need to know is what kind of engine this is.. can anyone help me out from the pics I have?
Post Options Post Options   Thanks (1) Thanks(1)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 1:13PM
302 Cubic inch 2 barrel carb. Looks like you have air conditioning and manual brakes too.
Edited by lynchster - 07-October-2017 at 1:14PM
91 F-150
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingMe Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 1:47PM
the car hasn't been driven since 91 she turns over but no start any ideas on where to begin troubleshooting?
Canuck View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Canuck Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 3:09PM
your three things to look for are air, fuel and spark.
it's pretty safe to assume you have air, as long as your carb isn't filled with crud.
I would recommend testing for spark first. If you have a pacemaker, don't do this, get someone else to do it.
If you have spark, then you need to look at fuel. Try cranking the car while you spray starting fluid (or WD40 etc) into the carb. If the car starts to catch and seems like it wants to start, you have a fuel problem.
72 Montego MX Wagon
Post Options Post Options   Thanks (1) Thanks(1)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 3:38PM
Do you know anyone who knows anything about older cars? If you do some supervision might not be a bad idea. Some of the suggestions can have disastrous results.
91 F-150
Post Options Post Options   Thanks (0) Thanks(0)   Quote Canuck Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 4:00PM
An appropriate fire extinguisher is never a bad idea.
72 Montego MX Wagon
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 4:58PM
1st thing i would do is disconnect the fuel line from the fuel pump so you don't contaminate the carb
2nd check for fuel spraying from accel pump nozzles in carb. if no accel pump shot, fill float bowl through the vent and check for accel pump shot again
3rd clean the points with fine grit emery or wet-sand paper & see if it has spark
after you have spark, 1 second shot of starting fluid into carb and crank
whatever you don't start changing settings that should've been correct the last time the car ran
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 5:03PM
then if the motor pans out get yourself a breaker point conversion module rather than replace the points
$ well spent Wink
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2017 at 5:20PM
you can pour a small amount of gas down the top of the carb and it will run for a couple seconds but i'd check and clean the points!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 08-October-2017 at 1:50AM
the concern in priming the engine by fuel down the carb is washing any oil off the cylinder walls
spraying a healthy dose of WD-40 down the open carb while it's cranking isn't a bad idea
the float bowl vents i mentioned earlier are the 2 tubes sticking up near the front of the carb, they lead to the float bowl where the carb stores it's fuel to run through the metering system properly
you'll definitely want to keep your face away from the carb while trying to start it, new & been sitting engines have a tendency to sneeze high velocity atomized gasoline & fire. hard on the eyebrows. worst case you get a shot of gas in the face then a backfire.
Edited by Rockatansky - 08-October-2017 at 1:57AM
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 08-October-2017 at 3:52AM
Disconnect fuel line.
Drain tank.
Replace points and condenser.
Check for power at coil.
Try some starting fluid.
2005 F-150 STX 4.6, 3.55 LSD
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingMe Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2017 at 1:38PM
Thanks for the advice everyone. Ill update the results soon
