Spark plugs!!! |
Postma98
Member Joined: 25-March-2017 Location: Logandale, NV Status: Offline Points: 51 |
Posted: 03-September-2017 at 10:28AM |
Anyone know what spark plugs will fit my 429...i don't know why but the autolite APP-45 is too big in diameter. I need to know before tomorrow, as always thank you
aquartlow
#45's (Autolite) are 18mm plugs, what cylinder heads are you using(casting # above center exhaust ports)? Autolite #3924's are a good # for the smaller 14mm plugs.
Some 429-460 cylinder head casting number's using 18mm plugs C8SE C8VE C9VE DOVE-C Some 429-460 cylinder head casting numbers using 14mm plugs DOOE-R D2OB-AB& D3AE-FA(POLICE INTERCEPTOR ENGINES) D2VE D3VE-A2A Hope this helps. BTW, check plug threads carefully, somebody may have installed "adapters" to the 18mm heads to allow for more plug choices in the 14mm size. Just a thought. If you do find that the 18mm plugs fit, try an NGK WR5, I have been real happy with these since switching from Autolite 45's.
Edited by aquartlow - 03-September-2017 at 11:19AM |
