  New Posts New Posts RSS Feed - Sport Door Panels
Sport Door Panels
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: Sport Door Panels
    Posted: 05-September-2017 at 1:09PM
Does anyone know if the 1972-73 GTS rear interior panel is the same for both formal and fastback?  I know the fastback would used a different window felt because of the bigger window, just not sure if the panels themselves would interchange?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2017 at 3:40PM
as far as i know they are different? different window angle???
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2017 at 9:22PM
I used 72 Torino sport rear panels in my 72 Mercury MX (formal roof) when I added Torino sport front door panels, and they fit just fine. No reason to think they wouldn't work on the formal Gran Torino cousin, but I don't know that with 100% accuracy, of course.
Matt
1969 Mercury Marauder 390
1972 Montego MX
2003 Mercury Marauder 300A
1994 F-150 5.8
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 3:11AM
really!!! i was told they wouldn't work, fit different, and so on... so i custom made my rear panels to match the sport door panels Confused
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 4:36AM
Matt were they from a formal roof Sport?
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 9:16AM
Oh. Well.......umm. Ok, you got me. I don't know which body style it came from. I retract everything I previously said in the post, and will here ever after keep my trap shut about things of which I do not positively know! Sorry to the OP.....Dead
Matt
1972 Montego MX
1994 F-150 5.8
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 11:53AM
From what i understand the fastback sport rear panels are molded plastic, the formals are vinyl like the rest of tbe cars?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 1:21PM
Matt, don't apologize, it's all good.  We're all trying to figure it out since no one seems to know for sure.
The GTS cars with either fastback or formal roofs came with the plastic molded door panels front and rear.  I am just not sure if the formals used a unique panel for the rear or if it was the same panel, but with a different window sweep (shorter for the smaller windows).  I can't even find a good pic although a a formal Roof GTS rear interior.
All other non-GTS Torino's had the vinyl door panels for 1972-73.  Although, there was one member who had a '73 GTS with the '74 style interior and vinyl panels. Although I think that it was a late build.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 2:00PM
I found this car online.  If you look at the pics you can kind of see the rear panels.  This car has the correct sport panels.  I can't tell if they are the same because the photos don't show much.
http://www.mjcclassiccars.com/1972-ford-gran-torino-sport.shtml
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 2:31PM
Matt I don't know either was just a question. The last picture is definitely a formal roof car with plastic panels. Can't tell if it is different from a fastback though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 3:06PM
Sail panel might cover up the window difference...
Never seen plastic panels in the rear of a formal, or vinyl in the rear of a fastback.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 3:57PM
That's what I was kind of thinking too Randy.  Fastback cars never should have had vinyl panels, since all were GTS's.  Formals that were GTS's should have had plastic, no GTS formal cars should be vinyl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2017 at 4:32PM
Malcolm should know his car is a formal sport...
