  New Posts New Posts RSS Feed - spring pads
spring pads
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: spring pads
    Posted: 29-July-2018 at 11:55AM
Ok here is the request. started removing spring from pinto. Found both rear are broken. found springs. Spring pads are bad can not find them any were. Asked pinto car club not one response. Seems someone other than me has replaced rear springs and needed pads. I called about 6 dis with no luck. Any help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2018 at 1:49PM
the metal brackets / blocks that weld onto the axle tubes and locate the leaf spring center bolt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2018 at 2:55PM
no he's needing the rubber pads that go between the leaf springs and the spring perches that you mentioned
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2018 at 3:16PM
Cougar uses rubber leaf bushings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2018 at 3:21PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2018 at 3:31PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2018 at 3:36PM
yes and the mustang II's use them as well i messaged sal since he's into m II's... no reply back yet (probably because he's busy kicking himself, for selling his torino today Cry)
bob you need to measure the spring width and pad length as well as the button knob diameter something should fit....
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2018 at 12:57AM
Thanks for reply caugers were close except mine have a rectangular raised part instead of a little bump. Will measure and reply
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2018 at 1:07AM
Found them I think. MustangII parts co never came up when I posted on google but a mustang guy sent me the info they look right makes sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2018 at 4:06AM
Well ford calls them insulators found them out of stock. The size is 53/8 by 2 1/2 knob is 2 1/4 by 1in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2018 at 1:52PM
Green Sales?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2018 at 4:37PM
good idea!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 31-July-2018 at 7:04AM
What are green sales please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 31-July-2018 at 10:47AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 31-July-2018 at 1:02PM
Green Sales has tons of NOS Ford parts.  They are a good company to deal with.
Read below:
"Welcome to Green Sales Company, supplier of obsolete Ford parts and Lincoln / Mercury parts.  Our Ford parts inventory represents all Ford and Lincoln / Mercury products from 1950 to the present.  While we have no direct connection with Ford Motor Company, we do supply NOS / OEM parts made available by Ford dealers on the secondary market.  Our staff is as knowledgeable as any Ford Parts Department. "
Edited by 72FordGTS - 31-July-2018 at 1:03PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2018 at 8:27AM
dayton green sales no go. need to find out galaxy or caugar size if same could weld up slot and go with hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2018 at 10:25AM
Prothane covers Pinto pretty well, maybe they'd be interested in producing the rear leaf isolators?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2018 at 1:43PM
Will call nothing to loose they do not list in catalog. It appears only the v6 used this 8in rear rest were 6.or7.5.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2018 at 3:35PM
i'd think they are the same? years ago we got a 8" from a 79 v-6 wagon at u-pull-it and bolted it right in on my step bros mustang II replacing the weak 7.5 or whatever the stop sign looking rearends were
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2018 at 5:52AM
No luck they had nothing for 2.5 spring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 11-August-2018 at 7:06AM
found them by luck general spring They were listed under Granada or Monarch they had 10.Ordered the springs also $417 this is getting expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-August-2018 at 3:12PM
are the granada springs a direct replacement???
 are you getting any wheel hop? you could throw a set of old school slapper bars on there...
JEGS-Performance-Products-64405-Universal-Leaf-Spring-Traction-Bars
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2018 at 8:42AM
Wheel hop hell it is just a shell now. going to try pic again. side note has anybody ever tried steaming foam to bring it back going to start seats for ltd2 soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2018 at 9:48AM
IDT steaming degraded foam is a good long term solution?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2018 at 1:44PM
I have a clothing steamer will give it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2018 at 6:26PM
i've seen my upholstery guy steam foam to get it to puff up and flex when fitting new vinyl cover on the foam to get it to relax and fit the seams straight, he has a wand attached to his steam pot so it can be inserted in the vinyl cover from the edge. but IDK if it would work if the foam is starting to break down and or really degraded???
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2018 at 12:29AM
will see that is my next move, at 73 that might be a while. been three yr on pinto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2018 at 2:39AM
Ok new springs painted one old one removed,had to cut off the end to remove bolt. One seat taken apart. That was a job in it self. I know pic I will take some of other seat. Problem is at my age if I stop to take pic I will not get going again.
