starter problems |
73torinogt
Member Joined: 23-January-2010 Location: nashville, il Status: Offline Points: 63 |
Posted: 04-October-2018 at 11:22AM |
I keep burning up starters in my 73 Torino. The last one was a new one instead of a reman. Got it in started fine. Went out about a month later, nothing. Switched batteries, changed relay, still nothing. Any ideas what going on?
73TorinoGT
original ground cable? change it even if it's new, get a good one with terminals that are poured / cast in place onto the cable, not crimped crap. you can sweat solder into a crimped terminal but it may already have corrosion in it from the boat ride over here. change the positive cable too if it's crimped or maybe you're just having bad luck ... Edited by Rockatansky - 04-October-2018 at 11:44AM |
did you try jumping the solenoid? to see if any power across there...
73torinogt
Are you talking ground from battery to engine? It has been replaced, but I think it is a soldered one.
Yes, I tried jumping across the relay. Nothing |
73TorinoGT
hogfiddles
Moderator Group Moderator Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1511 |
Fuse or ignition switch
aquartlow
You may want to get rid of the stock style of starter for that year and get a later model PMGR starter, I went this route for my Ranchero and will never go back to the original style of starter. Here's the difference, stock '76 460 on left, '92-'96 F250-F350 460 PMGR starter on right:
If the battery or it's connections are not "up to snuff" it can damage electrical system parts. May want to take the starter out and bench test it with your battery and a set of "good" jumper cables to rule out the starter and/or the battery. Also makes sure you have a 12V signal to the starter solenoid's "S" stud(fender mounted solenoid) when you turn the key to the start position. If you install a new starter, whatever kind you want, pull the coil wire and crank the engine over a few times then feel the ground and power cables. The cable that feels warmer/hotter than the other is the one with the most resistance and it has either a bad connection, bad termination point or is just subpar for the starting system. Good luck.
Edited by aquartlow - 05-October-2018 at 10:13AM |
73torinogt
Would you have apart number for the starter on the right. It looks like it would be easier to install and more room away from the header.
Thanks for all the help, guys! |
73TorinoGT
aquartlow
Definitely allows more clearance from my PS header, not sure what your application is (engine/trans)but this is what/where I ordered mine from. https://www.dbelectrical.com/products/ford-mini-starter-truck-van-mercury-460-engine-3226-sfd0030.html
73torinogt
73 Torino gt fastback with a 302 motor
73TorinoGT
bamatorino73
New Member Joined: 06-September-2018 Location: Pinson Alabama Status: Offline Points: 11 |
I had a problem like that. After changing battery, starter and solenoid. I found all I needed to do was to ground the engine block.
cdavis 73 GTS 351c Q laster stripes
