  New Posts New Posts RSS Feed - Steering column cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Topic: Steering column cover
    Posted: 18-March-2017 at 6:54AM
Does anyone have decent pictures of the two halves of the column cover? I'm in the process of pulling the steering column but can't seem to figure out how to split the cover.
I've worked around with probes at the seam but can't seem to draw a mental image of what the latching mechanism looks like.
Edited by lynchster - 18-March-2017 at 6:54AM
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2017 at 8:12AM
I do not have pics, but the 2 halves come apart after removing the 2 Philips head screws on the bottom half of cover. The cover halves fit together with sort of a "snap", the front of the covers that fit below the gauge cluster one half has a forward facing pin and the other has a rearward facing female socket the pin fits into. I found it easier to remove the gauge cluster surround first. If you separate the end of the covers nearest the steering wheel, then carefully spread the halves apart and using the front area as a hinge, you can slide the lower cover back enough to disengage the pin from the upper cover's socket, then remove it and the upper cover from the column. Hope this helps.
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2017 at 8:56AM
I've taken mine apart a few times without breaking the tabs, I found the trick was to undo one side and then the other just falls apart
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2017 at 1:43PM
I managed to get them apart and as an added bonus I didn't break them in the process. Mine didn't have screws but it had the two retainers.
This page was generated in 0.090 seconds.
