Steering Column Lengths? |
mlachance112785
Senior Member Joined: 31-May-2012 Location: Dighton, MA Status: Offline Points: 343 |
Posted: 22-June-2014 at 9:50AM |
Are there different lengths in column shafts? I just tried I stalling a tilt column in my 77 cougar. Theres atleast 2 inches between the shaft and the collar. I thought the column was from a 76. Has this happened to anyone?
77 Cougar XR7 460/C6
aquartlow
The column is collapsible by design, try attaching a pair of vice-grips above the machined area at the bottom of the steering shaft. Take a hammer and drive the vice-grips downward, away from the steering wheel.
i put a tilt column (from a 75? t-bird) in my 74 torino,everything from the mounting brackets up to the wheel were the same length, but the end of the shaft was about 1 1/4" longer over all, so i cut it at the taper and back about an inch, rewelded it works perfect! also ground off the shifter boss so it will be a tilt with floor shift
Edited by californiajohnny - 22-June-2014 at 10:40AM |
aquartlow
DAMN ERROR MESSAGES, trying to attach pic to explain . Mark the inner shaft before trying to drive the inner shaft out of the steering column tube, to know how far it needs to be driven.
Edited by aquartlow - 22-June-2014 at 10:46AM |
mlachance112785
Got it.
Thanks for the replies. |
ramair351
Senior Member Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
it depends on the gearbox, the saginaw box and ford box use two different length shafts, but you either push in or pull out the collapsable shaft as required
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
