Steering issue! |
Turbo301
Senior Member Joined: 11-March-2007 Location: London, Ontario Status: Offline Points: 331 |
Posted: 25-June-2010 at 5:32AM |
Hi Guys,
Just when I thought my car was finally cured :). I was at a car show this past weekend (only Cougar out of, like, 500 cars!) and the steering jammed-up, or got super-stiff at least, when trying to turn counter-clockwise. I gave 'er and there was a mechanical popping/clicking noise, and it freed up and turned fine. The highway drive home was fine. Then, just last night, while backing into my garage, it did it again!
In both cases, clockwise turning was fine, and both situations were at nearly-stopped speeds.
Any ideas what the problem might be? Are my recirculating balls not recirculating? A sticking lingage perhaps?
As usual, thanks for any pointers!
1977 Cougar XR7
1980 turbo Trans Am 2009 Pontiac G8 GT |
GranTorinoSport
Unless there is binding in a steering component (tie rod, other links and arms), then I'd say for sure it is the steering gear.
Take a close visual inspection of the steering linkage underneath first, however. Look for anything with evidence of binding. If you are adventurous enough, disconnect the pitman arm from the steering link and with the front end in the air try and actuate the steering by hand and also the linkage by hand (now disconnected from the steering gear). You should be able to make a determination then. |
Webmaster |
Psquare75
Without seeing it, I'm going to guess steering box.
GranTorinoSport
The more I think about it, ditto to Paul.
Webmaster |
Regul8r
yup thats what I would say!
Something in the steering gear box itself.
Turbo301
Thanks for your help, guys, that at least gives me something to narrow down to! It drove fine yesterday, even at low speeds, but perhaps there is a particular worn ball and, when it hits a particular part of the ball return or something like that, it gets jammed up. Fudge ^_^.
1977 Cougar XR7
Psquare75
Think of it as a perfect time to upgrade to a 3:1 box
72BlackGTS
Senior Member Joined: 10-April-2007 Location: Millerton, NY Status: Offline Points: 871 |
Check the pressure valve in the back of the pump. Hows the fluid look? Sounds to me like your pressure valve is sticking intermitently. Good luck. Ron |
Ron
1978 LTD II Sport-Green 2003 HD Road King Classic 100th Anniversary |
Turbo301
Hmm, that's an interesting possibility; the steering did kind of feel like it was going to manual force (still turned, just really heavy). The pump is just a giant black box to me (literally - big and black), so other than the fluid I'm not sure what to look for. I'll consult my manual when I get home, though.
Thanks!
1977 Cougar XR7
