  New Posts New Posts RSS Feed - Stock timing pointer
jdproper73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdproper73 Quote  Post ReplyReply Direct Link To This Post Topic: Stock timing pointer
    Posted: 16-June-2019 at 6:38PM
Hey Guys and Gals,
I'm having trouble starting my 351W. I'm wondering if I have the timimg pointer in the right place. Should be on the passenger side underneath the alternator or on the Driver side near the power steering?
Jason
78' Ranchero 351w/FMX
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2019 at 7:33PM
mine on my 74 is on the passenger side IIRC but some years were opposite i think may depend on what year of timing cover and balancer you have? i think the later windsors had it on the driver side...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2019 at 7:13AM
Passenger side about the 10:00 position. Should be a folded metal pointer that bolts on with two of the timing cover bolts
Unless a really early block/ rotating assembly, which MAY be driver side about 2:00 position which would be a cast pointer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2019 at 12:26PM
bolt hole spacing should only allow it to fit in 1 place?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdproper73 Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2019 at 4:12PM
Thank you Guys and Gals. I replaced the timing cover, timing chain with a true double roller timing chain. Replaced the water pump, 4bbl aluminum intake manifold, a hydraulic flat cam, lifters and push rods, and 600cfm holley with vacuum secondaries
This page was generated in 0.124 seconds.
