  New Posts New Posts RSS Feed - stud bolts
stud bolts
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: stud bolts
    Posted: 11-August-2016 at 3:04AM
To save me looking all over were can you find the double threaded bolts for the turn signals Have a nice set but the studs are broken off or missing.
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 11-August-2016 at 2:27PM
You lost me, the self tapping/ standard 1/4 20 thread for the lens?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-August-2016 at 3:17PM
sorry, i'm confused too
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 11-August-2016 at 11:53PM
I may be wrong, but I believe he is talking about these little "jewels" on the back of the turn signal housings that allow the housings to attach to the fiberglass front header panel:
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 12:15AM
that's them and yes they are a self taping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 12:37AM
How many do you need? I may have one or a few from broken housings that I have kept for "some" reason. CJ, hooked me up with a GREAT set of housings so my older, marginal set(s) may have just become donors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 3:25AM
I need three. These have no cracks only one stone chip.Did you repaint the silver and black. If so what did you use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 4:57AM
OK I will see what I have. When I re-did my TS lights, I opened them up and used mirror tape on the inside, resealed them with clear epoxy(all the way around to make them water tight except for a small weep hole on the very bottom). I then taped off the clear plastic and painted the "crossbars" and/or silver trim the same as my Ranchero's body color(did the same on my grille). Here are some pics, they are "just" a bit large, but so is the Ranchero Wink, it does give a better look to what I did:
Edited by aquartlow - 12-August-2016 at 5:04AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 5:59AM
how did you get it apart without breaking it.
Ranchero Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 6:13AM
Warm them up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 6:17AM
Originally posted by Ranchero Fan Ranchero Fan wrote:
Warm them up?
Yep, used a heat gun and a thin flat blade screwdriver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 6:31AM
Bob, you could probably use  a paint pen, like Todd used for the dash trim, available at an art supply store or fabric store  (JoAnn fabrics?). while there're off use a lens polish, or toothpaste to clean up the lenses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 6:44AM
Yeah, totally forgot about the Krylon silver leafing pen(Thank you Ranchero Fan Thumbs Up), works excellent on the dash trim lines, not sure how well it would hold up on the exterior surfaces though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-August-2016 at 2:38PM
Bob,
  I got 2 of the needed studs for the TS housings, I actually broke one of the housings removing the 2 studs, won't risk another housing. Send me a PM if their still needed/wanted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2016 at 7:59AM
I will try the heat idea on the old ones.Removing the broken studs cracked the housing but not that bad I hope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2016 at 8:07AM
FWIW the back of the housings are ABS plastic so they could be glued with ABS pipe glue if needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2016 at 8:12AM
One of the reasons I opened them up/resealed with epoxy was because I lost the face of one of the TS's, figured once opened I would restore the light housing interior and have better reflectivity with the use of the mirror/chrome tape. The epoxied housings WILL NEVER come apart again unless they are bashed/crashed. Good luck and take your time, you'll ne surprised how quickly they come apart once one side is loose, getting there takes a bit of patience though.
Edited by aquartlow - 13-August-2016 at 8:12AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2016 at 10:21AM
Patience WinkGrasshopper
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2016 at 11:01AM
LOLLOL Shocked showing your age there brian Wink
72BlackGTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72BlackGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2016 at 11:17AM
The last set I took apart i had them in boiling water for a few minutes. The hot water worked from the inside and out and they came right apart. Just a razor blade to cut the sealer. Slid right through it like butter, my .02 cents.
Ron
1978 LTD II Sport-Green
