  New Posts New Posts RSS Feed - Suspension upgrades
Suspension upgrades
va2ir View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote va2ir Quote  Post ReplyReply Direct Link To This Post Topic: Suspension upgrades
    Posted: 04-October-2016 at 6:09AM
Good day. Ian here from Montreal.
We did about 2000 miles in the Torino this season, Carlisle and the show in NYC. Uncle Paul beat on my car twice, and it survived!  But in NYC he called it a "floatuh" - floater.
And he;s right.
I changed the front and rear shocks to 96 crown vic touring shocks from Monroe about 10 years ago. I added a factory rear sway bar off a cougar XR7.
Ball joints, tie rod ends, idler arm, have all been changed to new.  Steering box could use some improvement. I can turn from 11 oclock to 1 oclock with very little feeling.
Aside from that, it is what it is when I bought the car in 2000.  Springs could be original from 73. I don't know.
In any case, I'd like some RECOMMENDATIONS on what owners have done to beef up the handling of our cars.  Springs?  From what model/year?  Shocks? Which manufacturer and for what car. Steering box?  Addco sway bars?  Poly bushings?
I did see an interesting article about a cross member for lincolns, that bolted to the torque box, then to the center engine member, and then to the front rad support.
Let's try to keep this thread on topic and not go too far off the track.
thanks
You can reply to me off list
va2ir at securenet dot net
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2016 at 10:08AM
I boxed my rear lower control arms,poly bushings throughout, oem 1 1/8"front bar,addco 7/8" rear bar
gnrlee01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2016 at 10:31AM
i too would like to know what to look for or where i can get a direct swap out for a steering box that will make my steering wheel more responsive. driving my girlfriends corvette has made me realize just how sloppy and unresponsive my steering wheel is compared to hers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2016 at 2:27PM
What is your car now?  A '73 Torino?  Do you know what suspension package you have from the factory? What are you goals for the car in terms of ride and handling?
The coil spring thread is overwhelming to many, but there is tons of good info there on what springs to use.  I'd suggest a more performance oriented shock, Brillstein's, Monroe Severe Duty shocks or KYB's.  Addco is the only aftermarket source for sway bars and they offer the biggest front and rear you can get for our cars (1 1/8" front, 7/8" rear).
If you have a lot of slop in your steering, check your front end first.  Make sure that you don't have any worn parts.  The stock steering boxes on these cars are slow and over boosted.  You can get a quick ratio Ford box from Lares. My preference is for a Saginaw quick ratio high effort box, but it is a little bit more work to swap if your car doesn't have a Saginaw box in it now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2016 at 3:15PM
mine is a 74 gts with a 460. currently i have a brand new set of front and rear coil springs that i ordered for a 76 torino station wagon with a 460 and a/c. i have not installed anything yet, because i am in the slow process of gathering all the various parts i want first, before beginning any tear down. i have a front sway bar on the car, i am ASSUMING that it is a 1-1/8 bar, based on the fact that mine is a 460 car, but i have no rear sway at all.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2016 at 10:39AM
Your car likely has a 15/16 sway bar, which was standard for most Torinos in 1974 with the base suspension.  The 460 engine option made no difference on the sway bar size.  If you car has heavy duty suspension, then it would have a 1" front bar and a 11/16" rear bar.  Bigger bars were available for police package Torinos.  The 1 1/8" bar was only used on the Elite in 1974.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2016 at 11:08AM
ahh...ok. thanks for the info and correction.
you guys that have boxed in your control arms, when you were welding on them, were they previously galvanized, or just painted from the factory?
Post Options Post Options   Thanks (1) Thanks(1)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 05-October-2016 at 12:26PM
Just painted steel.... and here's a link to the HOW TO thread.
GOOD LUCK
Edited by TV 2M8O - 05-October-2016 at 12:28PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote va2ir Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2017 at 6:02AM
Hi guys. hope you had a good winter.
So I got all my parts together and started on the rear end left side. Got the lower arm off, after cutting the bolts, cleaned it up, boxed it in, pressed in new bushings, then the fun started on reinstalling. I installed the front bolt, but the axle end was off by an inch. So should I be raising the car from the frame first and then support the axle? Theoretically, if both the frame and axle are suspended, nothing should move.
Now working on the upper arm (dog bone). Have to keep the shells of the bushings. Again bolts seized tight. No room to get a cut off wheel in the frame pocket....so I hope the sawzall will cut the bolt.  ANy other ideas? I have no access to a torch nor plasma cutter.
Thanks
Ian R.
Have a good time in Carlisle for those that are going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2017 at 1:41PM
I would try to save the OEM hardware if possible.  Have you tried PB Blaster? You can usually buy a mapp gas torch with an O2 tank pretty cheap from a hardware store.  They get a lot hotter than a propane torch, might be enough to loosen the nut.  You could also try a nut splitter, which would at least save your bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2017 at 9:23AM
Sounds painful. LOL
