  New Posts New Posts RSS Feed - Swamp Thang: Electrical issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2014 at 7:51AM
accessory circuit breaker power feed, I guess it would go through the ignition switch for control?
does yours have a power rear window & does it work with that disconnected?
does it work with the loose wire temp'd to the power terminal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2014 at 1:47PM
yes, that would be for pwr seat opt or rr defroster (ckt breaker)
bmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmf Quote  Post ReplyReply Direct Link To This Post Posted: 29-January-2014 at 3:03PM
In case you have not found it.  There is a wire bundle that runs from the dash, under the seat, and to the rear.  It has connectors and a ground or two.  It is in the channel directly under the seat on the drivers side.
"I am completely broke and have the ability to sustain that"
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 29-January-2014 at 5:22PM
I have that circuit breaker on my 75 Sport, and it has neither rear defrost or power seats?
I am of course removing it as part of the re-engine, but I was trying to figure that one out. I am replacing it all with a heavy duty terminal block and the solenoid is now down on the starter.
Those wires going from that CB feed the ignition power and others.
This page was generated in 0.108 seconds.
