  New Posts New Posts RSS Feed - taller intake manifolds
ssregal39 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Topic: taller intake manifolds
    Posted: 20-April-2016 at 3:07PM
Anybody mess with intakes? I'm wondering what will fit under the stock hood. RPM? Airgap maybe?
Thanks in advance
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2016 at 3:11PM
I have the air gap. It fits with stock air cleaner and hood scoop hood. Will not fit with the factory ram air. That is for a 72. -Rick-
Edited by 72GTS351CJ - 20-April-2016 at 3:13PM
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2016 at 3:13PM
I guess I should have put for a 351W.
What motor on yours?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2016 at 3:15PM
Cleveland. Sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2016 at 3:17PM
Ahhhh that's a little lower deck wise. hmmmmm
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2016 at 4:46PM
you say "stock" hood, do you mean the flat hood? or the sport hood with the scoop?
 i have a 351W with a offenhauser and a 1/2" phenolic spacer with a holley on top of that with a aftermarket oval filter (2" tall?) and that all clears the scooped hood fine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2016 at 9:28AM
Yep flat hood 78 thunderbird. I didn't know there was a sport hood.
Edited by ssregal39 - 21-April-2016 at 9:29AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2016 at 1:23PM
not for a 78 T-bird. Your car just has the flat stock hood. The only midsize car that would have a raised or scooped hood would be the  72 torino sport and the 72-73 Montego GT. All the others are flat
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2016 at 1:25PM
Got it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2016 at 3:01PM
opps, my bad, i assumed you were referring to a 72 torino Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2016 at 3:08PM
big air cleaner with performer intake and edelbrock carb on a 302 was a bit of an issue on my 79 T-bird.
of course, a drop-base that fit the edelbrock carb would have helped...
2005 F-150 STX 4.6, 3.55 LSD
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 22-April-2016 at 12:30PM
Thumbs UpI have a parts car. Maybe I'll hack up a hood.
