  New Posts New Posts RSS Feed - The Official TIRE SIZE THREAD
 Post Reply Post Reply Page  <1 45678 12>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2010 at 4:59AM
4.5 is a MUST in order to JUST fit inside the wheel well.
5 will fit without any chance of rubbing
Carl
3 Formalroofs (2x72, 1x73), 72 GTS
90 T-Bird SC, 3.8l SUPERCHARGED
97 Dakota 2WD,Ext cab, 5.2L
Thats just my stuff!
You should see the wife's "HER STUFF" list!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2010 at 1:21AM
They need to be a 5" offset Pete, otherwise will stick too far out.
These Aero Racing wheels are a 15 x 10, 5" back space.
Without screwing you all up a bit, keep in mind, these are technically almost 11" wide, but the 10" is bead to bead area.
Anyways...the 15x10, 5" back space.
With the short 295 50 15 on all 4 corners, you can rocket down the road.
Just as a warning, big wide tires on any vehicle, will want to grab at ruts some times.
Out back, though, you are fine.
And, lastly, anyone interested?
I had ta ask again Wink
I will do $125 shipped to your door for the pair...and it keeps me from wanting to mount up some DOT drag slicks...
Andrew
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2010 at 1:52AM
andy those wheels of yours look awesome. I cant believe you didnt want to use them!     i have an obssession for some weld draglites right now.    i had a chance on some locally through craigslist, but he sold them before i could get over and measure the backspace.  we will hope they wouldnt have fit.
-Pete
2000 mustang
1970 torino Cobra
1965 Falcon futura
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2010 at 4:05AM
I know...I would run them on all 4 corners, but I can't run a 15" wheel.
If I could I would of ditched my 5x4.5" bolt pattern and got some new hubs and gone 5x5" with my nascar wheels.
Andrew
Ranchero72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero72 Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2010 at 6:13PM
Has anybody ever bought a set of these?  I'd like to do a set of these on my car but I'm afraid they won't fit by my calculations.  As per my math and reading through this thread a couple times:
18x9 wheel is 10in wide and has a 24mm offset, 0 offset is at 5in and you add 24mm (0.944in) for a total of 5.95in of backspacing which is a bit too much.
18x10 wheel is 11in wide and has a 22mm offset, 0 offset is at 5.5in and you add 22mm (0.86in) for a total of 6.3in of backspacing which is also a bit too much.
I'd really like to have a set as I have OEM Magnum 500's and 14in tires are hard to find, plus the cool factor.  Thanks!
Originally posted by rtgreen rtgreen wrote:
This vendor is running a sale on Magnum 500's from 18x10 to 20x10 in Deep Dish styles. The 1994-2004 Mustang fitment will work on our cars. Enjoy!
Edited by Ranchero72 - 12-May-2010 at 6:15PM
'72 Ford Ranchero 500
-351C C4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2010 at 6:40PM
You'd need some massive spacers. IMO, that's a bad idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2010 at 7:55PM
I'd just run the 15x8 magnum 500...15" tires, with like a 275/60r15 out back and a 255/60r15 in front.
Big car...needs some sidewall.
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2010 at 8:05PM
bah, mine is fine on 50s and I plan to run 275 40 20s when I upgrade :).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2010 at 8:08PM
wel,, I'll find out soon enough if those 6 ply nitto's ride as stiff as I think they are going to.
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2010 at 8:13PM
lol, I have the same Nittos on my car, remember? I loved em.
moose0211 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moose0211 Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2010 at 8:35PM
I think I have figured out my set up, any flaws?
15x10s with on the back with 275/60/15 tires
15x8s on the front with 255/60/15 tires.
Still thinking about backspacing and offset.
-Lou
Lou and Brad
1972 Gran Torino
2008 Ford F-350 w/ banks
2009 Jetta TDI
2010 Jetta TDI cup edition
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2010 at 5:29PM
-Lou
COULD use 15X8 all the way around with those tires sizes.
Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote moose0211 Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2010 at 6:06PM
Wouldnt 275s on a 15x8 be very tall? I really like how Uantes car looked with the 275s on 15x10s, because the tires looked "big" as opposed to the low looking 295s.
Lou and Brad
1972 Gran Torino
2009 Jetta TDI
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2010 at 3:50AM
i have 275 60 15's on the rear of my car, just put them on. i will get pics up soon. yes they are tall, but in a good way.
-Pete
2000 mustang
1970 torino Cobra
1965 Falcon futura
albo74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albo74 Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2010 at 6:27PM
                    yes thats is what is on my 74 ,215-70s  7'' and 275 60s on rear, 8''   ansen sprint wheels, the whole deal ,wheels and tires was around a grand, S&H  old school ,  suspension is all stock.
Edited by albo74 - 24-July-2010 at 2:02PM
albos74gts
Carl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl Quote  Post ReplyReply Direct Link To This Post Posted: 26-July-2010 at 12:11AM
While installing my new drag radials today I decided to mount up a few different wheel/tire combos I have and take some pictures for you guys.
1st up: 255/50R17's on 17x8 alum wheels with 4.5" backspace.
-This is my road race/street setup.  I really like them a lot.
2nd: 255/65R16's on 16x7 alum wheels with 4.25" backspace from a Ford Ranger.
-I run these on my 68 Mercury.  At 29x10.5, they're pushing the limit of what will fit the 73 but I think they actually look nice.  Not a chance the tires would work on the front though, just too big.
3rd: 255/60R15 drag radials on 15x8 steels with 4" backspace.
-Same tread width as 275/60's but a little shorter.  I think they look a little goofy but they fit and they're sticky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2010 at 6:57AM
Man...I like the GT-M...'73's look bad ass.
I sort of always debated what I late model ranger wheel would have looked like. If that was a 8" wheel instead of a 7", I would of almost gone that route.
On those drag radials...I would of picked up the 295/65r15's. They are huge, fat tires but DAMN just fills up the tubs.
Andrew
Carl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2010 at 3:28PM
Thanks.  I would have preferred the new 295/55R15 size but it would have been almost twice the price with the new wheels they'd require.  These are the wheels I had and the 255's are what fit them.  Plus, with them having the same exterior dimensions as my street tires, I can use one as a spare.
Edited by Carl - 28-July-2010 at 3:30PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2010 at 4:00AM
this is what i am running now.  weld 15x8's
 3.5 b/s rear with 275/60/15,
4.5 b/s front with 235/60/15
-Pete
2000 mustang
1970 torino Cobra
1965 Falcon futura
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2010 at 4:31AM
-Pete
2000 mustang
1970 torino Cobra
1965 Falcon futura
This page was generated in 0.375 seconds.
