The Official TIRE SIZE THREAD |
Page <1 202122 |
Author | |||
Nuggets ![]() Senior Member ![]() ![]() Joined: 07-November-2014 Location: UK Status: Offline Points: 870 |
Width means nothing without profile ratio
Barnaby
429 powered 73 Stripper.....no comfort, just noise! |
n2fordwagons ![]() Senior Member ![]() ![]() Joined: 20-July-2013 Location: GA Status: Offline Points: 1939 |
40 & 45 series tires, like John is running on his Corvette, are way to low profile for our cars, unless your car is lowered significantly.
On my Montego wagon Fronts are 17x8 w/ 4.5" BS on 235-55 tires Rears are 17x9 w/ 5.25" BS on 275-55 tires ![]() ![]() |
Jeff
76 Mercury Montego MX Villager w/ 460 79 Ford Thunderbird w/ T-tops |
Here's how 17" 40 series tires look on our cars, with standard ride height.
Fronts are 275-40-17. Rears are 315-35-17. ![]() |
Jeff
I like the 315s I've got 275/60/17 on mine currently but do fancy some wider rubber. Was thinking 305 but 315 would be even better especially if I can get them in a 29" diameter or 31
Barnaby
Unfortunately, I haven't had much luck finding them in a taller tire. 275 seems to be about the widest tire I've been able to find in a tire tall enough for our cars. |
Jeff
unlovedford ![]() Senior Member ![]() ![]() Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 9613 |
On my gold car and red wagon, I run 17 X 8 with 235/55-17 front and 18 X 10.5 with 255/55-18 on the rear.
1972 GTSquire Wagon 1972 Torino Wagon 1976 Torino 1968 Cougar XR7-First batch 1972 Torino 460 1989 BroncoII/Jeeps/Titanimous Popeye and Brutus (Rams) |
I can buy a Toyo in that size over here, its an all terrain tyre but not an issue
Barnaby
Don V. ![]() Member ![]() Joined: 07-July-2017 Location: Michigan Status: Offline Points: 173 |
I assume you mean aspect ratio but would you explain why you say this please.
Power Surge ![]() Senior Member ![]() Joined: 06-March-2016 Location: Palm Coast, FL Status: Offline Points: 515 |
I think he meant the other way around.
Sal Mennella
Aspect, profile, same difference.
Because someone can say they run a 245-15 up front. Great! Butyiu try a 245/55/15 vs a 245/75/15 not the same at all! Same for me on the rear I could say I run a 275/16 which I do......but without the sidewall height it's useless. In my case it's a 60. But that'd be the largest height you can fit in at 30" diameter You could also run a 275/45 and have way more arch clearance. But you say you're running a 305-17 and miss the ratio someone buys some 305/55's it's not going to fit if 305/35 is the size they need. I'm just making up ratios here but you get the point |
Barnaby
And odds are someone will buy a size without checking then complain it doesn't fit under the car....
Barnaby
Actually not what I was thinking but you're right. kudos
Does that happen?
It's been years since I've considered this so maybe it's just "old school" nonsense today on my part but I don't see them as the same. Aspect ratio was a static number based on the off the rim section height and width. It doesn't take into account rim size. With the proliferation of low profile tires anyone using the number needs to ensure apples and oranges aren't getting mixed. Profile ratio was an entirely different animal. It's an active number based on a tires limits and used primarily by but not limited to engineers for matching a tire to a vehicle or in motorsports, conditions. It's use is necessitated by Newton's 3rd law of motion, "for every action there is an equal and opposite reaction." Can a tire handle the performance characteristics of a given vehicle or can a vehicle handle the performance characteristics of a tire. Look at the tire rotation directions through the years. Tires today may have the same inside outside profile ratios but they are not the same left to right. Don't put a right tire on the left side. The sticky tires used in F# racing would tear up a daily driver's drivetrain and there's a good reason why biased tires are almost a thing of the past. Consider a tire used by an airline where the drivetrain is separate from the tires. These tires are designed to get taller and thinner as they approach their "at speed" limit. The approach to traction between an auto and airline is very different. A tire has more then one profile ratio because it's an "in use" number. In my day anyway. In my day the equivalent and effective ratios were what mattered. Ensuring your tires matched the rear end gearing. Those cool, big tires often came at the expense of performance. Don
Whatbyoure listing as profile such as speed rating and load I'd class as specification or characteristics such as a V rating or DOT legality etc
Edited by Nuggets - 11-July-2017 at 12:39AM |
Barnaby
Barnaby, You're absolutely right. For road vehicles all the ratings come from or are adopted from the SAE. For the daily drivers it's not much of an issue anymore because of the research that has been done and the ratings. Sometimes the envelope gets pushed though. I can't say where I heard or read this but for the newest Veyron there is only one legal tire for the car at it's rated top speed. Even then the life of the tire at speed is rated in either minutes or miles at a cost of $30,000 for a set. I just looked that cost up. You can bet tire companies are working on tires set for a new rating to accommodate the car. The ratings exist for motorsports also. I'm not sure how familiar Brit's are with tractor pulling but when pulling started using engines like the Allison Merlin there were problems with the split rims on tractors and tires. That was solved by new ratings. Jim Thorton who in the 60's invented the drag racing torque cancelling chassis, is credited as the inventor of funny cars, was the head of Chrysler's race vehicle design and the primary driver of Chrysler's drag racing team talked a lot about how tire profile didn't keep up with the sport. Nitro burners were around long before they were legal on the strip because of tires. Even today the tires require being screwed to the rim. The ratings per tire are based on profile ratios which is about the tire in use and not a static, off the rim ratio of section height and width. And it is section height, not tire radius. "It's an adjustable wrench, Crescent is a brand." I heard this all the time growing up. I'm aware of how words and meanings change because of common use. I'm not at all being critical of you. Some things do irritate me but this isn't one of them. I'm only explaining what the meanings are for me. Don
Edited by Don V. - 11-July-2017 at 7:31AM |
yellowsportwagon ![]() Member ![]() ![]() Joined: 25-August-2015 Location: illinois Status: Offline Points: 167 |
I'm running 245/45 17 4 1/2 backspace on frt and 295/45 18 with 5 inch backspace on rear nothing hits or rubs anywhere. Car is lowered 1 inch in back and about 2" in frt
Edited by yellowsportwagon - 12-July-2017 at 7:34AM |
fordismyboss ![]() Senior Member ![]() Joined: 05-January-2014 Location: SF Bay Area Status: Offline Points: 219 |
72FordGTS ![]() Admin Group ![]() ![]() Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 2064 |
That's a sweet picture. I love the look of a '72 with meaty tires on the front end, which is why I run 8" tires on the front.
1972 Ford GTS Sportsroof - Survivor, One Family car |
72GTS351CJ ![]() Senior Member ![]() ![]() Joined: 30-November-2010 Location: NY Status: Offline Points: 1172 |
Love it!!! 14's never looked so good
72GTS Clint Eastwood Special
Page <1 202122 |
Tweet
