  New Posts New Posts RSS Feed - The Official TIRE SIZE THREAD
 Post Reply Post Reply Page  <1 202122
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2017 at 9:47PM
Width means nothing without profile ratio
Barnaby
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 12:39AM
40 & 45 series tires, like John is running on his Corvette, are way to low profile for our cars, unless your car is lowered significantly.
On my Montego wagon
Fronts are 17x8 w/ 4.5" BS on 235-55 tires
Rears are 17x9 w/ 5.25" BS on 275-55 tires
Jeff
79 Ford Thunderbird w/ T-tops
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 12:47AM
Here's how 17" 40 series tires look on our cars, with standard ride height.
Fronts are 275-40-17.  Rears are 315-35-17.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 1:11AM
I like the 315s I've got 275/60/17 on mine currently but do fancy some wider rubber. Was thinking 305 but 315 would be even better especially if I can get them in a 29" diameter or 31
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 1:18AM
Unfortunately, I haven't had much luck finding them in a taller tire.  275 seems to be about the widest tire I've been able to find in a tire tall enough for our cars.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 1:31AM
On my gold car and red wagon, I run 17 X 8 with 235/55-17 front and 18 X 10.5 with 255/55-18 on the rear.
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 9:11AM
I can buy a Toyo in that size over here, its an all terrain tyre but not an issue
Barnaby
Don V. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2017 at 12:37PM
I assume you mean aspect ratio but would you explain why you say this please.
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2017 at 12:38PM
I think he meant the other way around.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2017 at 3:53AM
Aspect, profile, same difference.
Because someone can say they run a 245-15 up front. Great! Butyiu try a 245/55/15 vs a 245/75/15 not the same at all!
Same for me on the rear I could say I run a 275/16 which I do......but without the sidewall height it's useless. In my case it's a 60.
But that'd be the largest height you can fit in at 30" diameter
You could also run a 275/45 and have way more arch clearance. But you say you're running a 305-17 and miss the ratio someone buys some 305/55's it's not going to fit if 305/35 is the size they need. I'm just making up ratios here but you get the point
Barnaby
And odds are someone will buy a size without checking then complain it doesn't fit under the car....
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2017 at 2:41PM
Actually not what I was thinking but you're right. kudos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2017 at 2:42PM
Does that happen? Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2017 at 3:06AM
It's been years since I've considered this so maybe it's just "old school" nonsense today on my part but I don't see them as the same.
Aspect ratio was a static number based on the off the rim section height and width. It doesn't take into account rim size. With the proliferation of low profile tires anyone using the number needs to ensure apples and oranges aren't getting mixed.
Profile ratio was an entirely different animal. It's an active number based on a tires limits and used primarily by but not limited to engineers for matching a tire to a vehicle or in motorsports, conditions. It's use is necessitated by Newton's 3rd law of motion, "for every action there is an equal and opposite reaction." Can a tire handle the performance characteristics of a given vehicle or can a vehicle handle the performance characteristics of a tire. Look at the tire rotation directions through the years. Tires today may have the same inside outside profile ratios but they are not the same left to right. Don't put a right tire on the left side. The sticky tires used in F# racing would tear up a daily driver's drivetrain and there's a good reason why biased tires are almost a thing of the past. Consider a tire used by an airline where the drivetrain is separate from the tires. These tires are designed to get taller and thinner as they approach their "at speed" limit. The approach to traction between an auto and airline is very different. A tire has more then one profile ratio because it's an "in use" number. In my day anyway.
In my day the equivalent and effective ratios were what mattered. Ensuring your tires matched the rear end gearing. Those cool, big tires often came at the expense of performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2017 at 12:38AM
Whatbyoure listing as profile such as speed rating and load I'd class as specification or characteristics such as a V rating or DOT legality etc
Edited by Nuggets - 11-July-2017 at 12:39AM
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2017 at 7:29AM
Barnaby,
You're absolutely right. For road vehicles all the ratings come from or are adopted from the SAE. For the daily drivers it's not much of an issue anymore because of the research that has been done and the ratings. Sometimes the envelope gets pushed though. I can't say where I heard or read this but for the newest Veyron there is only one legal tire for the car at it's rated top speed. Even then the life of the tire at speed is rated in either minutes or miles at a cost of $30,000 for a set. I just looked that cost up. You can bet tire companies are working on tires set for a new rating to accommodate the car.
The ratings exist for motorsports also. I'm not sure how familiar Brit's are with tractor pulling but when pulling started using engines like the Allison Merlin there were problems with the split rims on tractors and tires. That was solved by new ratings. Jim Thorton who in the 60's invented the drag racing torque cancelling chassis, is credited as the inventor of funny cars, was the head of Chrysler's race vehicle design and the primary driver of Chrysler's drag racing team talked a lot about how tire profile didn't keep up with the sport. Nitro burners were around long before they were legal on the strip because of tires. Even today the tires require being screwed to the rim.
The ratings per tire are based on profile ratios which is about the tire in use and not a static, off the rim ratio of section height and width. And it is section height, not tire radius.
"It's an adjustable wrench, Crescent is a brand." I heard this all the time growing up. I'm aware of how words and meanings change because of common use. I'm not at all being critical of you. Some things do irritate me but this isn't one of them. I'm only explaining what the meanings are for me.
Edited by Don V. - 11-July-2017 at 7:31AM
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 7:33AM
I'm running 245/45 17 4 1/2 backspace on frt and 295/45 18 with 5 inch backspace on rear nothing hits or rubs anywhere. Car is lowered 1 inch in back and about 2" in frt
Edited by yellowsportwagon - 12-July-2017 at 7:34AM
