  New Posts New Posts RSS Feed - Thermostat housing
Thermostat housing
grandpops4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Topic: Thermostat housing
    Posted: 25-February-2018 at 6:16AM
Hi All, what is the name of the part that screws into the water neck and has three vacuum lines and one wire on it..Thanks
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-February-2018 at 7:01AM
vacuum thermal switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 25-February-2018 at 7:14AM
Thank you ...you are 100 percent correct
gm
This page was generated in 0.061 seconds.
