tilt steering column? |
Kit Sullivan
Member Joined: 23-October-2008 Location: Florida Status: Offline Points: 112 |
Posted: 01-February-2009 at 12:30AM |
Would a tilt and Cruise-control steering column from a 77-79 T-Bird/Cougar be a direct bolt-in for a 1975 Torino?
"I'm too old to grow up now!"
mcford
YES.
GranTorinoSport
Only thing is you'll either need to re-use your ignition start switch (mounted top mid-column) from the old one, or cut the two connectors off the donor 77-79 car and use the new connector spliced into the existing harness (pin outs are the same essentially).
Easy. Just something to remember, that's all.
Webmaster |
