  New Posts New Posts RSS Feed - timing
timing
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: timing
    Posted: 15-October-2013 at 3:17AM
Anybody have an idea for timing on my 351w after the egr valve and smog pump removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2013 at 10:16AM
The same as when you had it installed. I would start @ 14 BTDC and work up to 18 BTDC. The more advance your engine has the smoother it will feel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2013 at 4:19PM
keep an eye on the total advance, if you arbitrarily throw an extra 10* onto the initial that the factory didn't account for you can get into too much advance on the top end, or even in the mid-range
Dan's suggestion is a good one for finding what the engine likes for initial, but after you find that you should have the distributor 'recurved' to accommodate the new initial setting
Scotty J changed his website, he used to have posted a tutorial on how to curve it yourself, he also provides the service still listed on the page under Services  http://www.reincarnation-automotive.com/home
Edited by Rockatansky - 17-October-2013 at 4:20PM
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2013 at 7:46PM
My 75 Sport still ran quite good after the emissions components were removed. It was a 351W and seemed to not mind having all the stuff disconnected. This is different from my 76 Elite with a 400 which seemed to run worse and be more temperamental without the emissions stuff operating.
I agree that having the distributor recurved is a recipe for success.
Edited by GranTorinoSport - 18-October-2013 at 5:16AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2013 at 12:39AM
If looking for more power and efficiency (WHO ISN'T), recurving your distributor will definitely help. I used the instructions from http://www.reincarnation-automotive.com/Duraspark_distributor_recurve_instructions_index.html and it made a great deal of difference. Good luck. Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2013 at 2:23AM
Thanks all, I guess I had better just set timing to spec. and leave well enough alone.If it ant. broke don't fix it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-October-2013 at 4:10PM
stock Censored sucks Thumbs Down
even Windsors like their advance Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2013 at 11:20AM
Check timing tomorrow and adjust idle.It took me 7yr. to find out I never hooked up the heat tube to the choke It use to take 5min. to idle down and about 10 to 15 cranks to start. Now 3 cranks and it starts and starts to idles down in seconds.
