  New Posts New Posts RSS Feed - Tire selection for 71 Ranchero
Jordanbrown123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Topic: Tire selection for 71 Ranchero
    Posted: 21-July-2017 at 7:54AM
Does anyone know the maximum width of the rear tire a 71 ranchero can fit? Rim dimensions?
ive got  245/60 14 in the rear and 225/70 14 in the front. Im looking for somthing a little more meaty, just never purchased tires/rims before.
Thanks for any input guys
71 Ranchero, 302.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-July-2017 at 4:54PM
i'm not sure on the 70-71 cars, but i'd suggest measure from the floor up to the bumper or some other reference point, measure from the floor up to the center of the axle for a reference, then remove the wheel, jack the axle up to your reference, then jack the frame up to that reference then put a straight edge against the axle flange, at the top of the wheel lip measure in to the straight edge make a note, measure from the straight edge into the inside of the wheelwell note that and check around for any narrower spots to see what width you can fit and what backspacing will work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2017 at 12:50PM
Thanks
71 Ranchero, 302.
