  New Posts New Posts RSS Feed - TIRE SIZE SUGGESTIONS
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: TIRE SIZE SUGGESTIONS
    Posted: 03-November-2013 at 3:16PM
Hi Guys
I have 15x7 rims for the front and 15x8 rims for the rear. Anyone know what size tires fill the rear well and will fit without issues in the front?
Thanks
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 3:52PM
I think some have used larger than this but...
I am planning to use this tire size based on experience of Picon3 who is using this on Lazarus.
Front: 255/60-15
Rear: 275/60-15
Also note that in 15 inch, you have limited options. For example I do not believe you can get a 245/70 anymore, etc.
A different front/rear tire size eliminates the ability to rotate tires. An added cost due to tire wear, but I am ok with it (as many others are also).
Speedway 650 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speedway 650 Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2013 at 5:30PM
I run 215/60s on the front and 275/50 on the rear of the Montego. The rim sizes are the same as yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2013 at 8:52AM
My 4 speed has 255/60 on 15 X 7 inch Magnums front, 275/60 on 15 X 8 Magnums on the rear.
1972 GTSquire Wagon
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2013 at 11:22AM
My Montego wagon has 15x8 Magnum 500 wheels on all 4 corners.  With 255-60-15 tires up front, and 275-60-15 tires on the rear. I wouldn't go any wider than that.
Edited by n2fordwagons - 04-November-2013 at 11:24AM
Jeff
79 Ford Thunderbird w/ T-tops
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2013 at 11:46AM
Same here. Mounted balanced and shipped fo 1150. Summit racing.U can't beat that deal. Good luck. ......Rick
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2013 at 12:16PM
Wow. $1150 for the tires and rims? I just dropped $825 for the rims caps and lug nuts and I thought I did well. What kind of tires did you get for that price? Does anyone know if anyone repops the Goodyear or Firestone oem style tire in 15 diameter? If so are they radials or the old bias ply? Thanks for all the help. I now have a idea what sizes fit and have been used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2013 at 11:06PM
Cooper Cobra radial gt. I seen them on another members car and thought they looked great being they said cobra. Didn't care about performance. It's all about the look. .
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2013 at 12:08AM
I've used Cooper Cobras before.  Great tire, and lower price than BF Goodrich.  For repops, try Coker Tire.  But, if price is a concern, you'll probably wanna stick with Coopers or BFGs.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2013 at 1:44AM
Looked at Coker. They make the oem style but not big enough for me. Price is up there also. I was thinking about BFF or coopers since I think I'm going with black side of tire facing out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2013 at 1:49AM
I have both brands of tires. BFG seem to wear a bit better, otherwise not a lot of difference until you step up to the high performance line.
Coker is local here. They have anything you can afford to buy...if your pockets are deep enough. Mine aren't, lol.
Edited by unlovedford - 05-November-2013 at 1:50AM
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2013 at 1:21PM
I'll be using BFG Radial TA's... 275/60R15's out back on 8.5x15 Americam Racing aluminum slots and 215/60R14's up front 14x6 factory aluminum slot mags.
