  New Posts New Posts RSS Feed - i6 to 351w swap
i6 to 351w swap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Topic: i6 to 351w swap
    Posted: 20-November-2014 at 2:56AM
hey guys, i am hoping to buy a bronco for a mud toy for rednecks with paychecks....and the one im interested in has a 300i6 5 speed manual tranny 4x4.....if i got it, i would want to swap to a 351w...what would i need? is it just a clean out n' in swap? obviously motor mounts and maybe tranny mounts might be different....but what would i have to change on the motor? fly wheel? im not that experienced in this type of swap. probably not the place to post about a bronco, but i thought you guys could help. thanks.
~Bryan
72 gts h-code (formal roof)
67falcon
04 f250 ''the great white''
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2014 at 2:58AM
i read that it with bolt up, like the belhousing pattern is the same.
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2014 at 11:34AM
Bell is the same. Flywheels are not (but they WILL bolt onThumbs Down) 351 is 28 oz. external balance, 300 is internally balanced. 351 also uses a flywheel with a 11' clutch as opposed to a 10 or 10.5 for the 300.
Tranny mount doesn't change if you use the same trans, motor mounts will have to change, and I think that the mount perches are different... front accessories are going to need work, new brackets at minimum. All that aside, these are easy trucks to work on, and parts interchange with F150 for the same era. Have fun!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2014 at 12:55PM
so what do i need here? balanced flywheel and 11' clutch?
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2014 at 1:55PM
Best bet is a clutch kit  (flywheel, disc, pressure plate, throwout bearing, pilot bearing) for a 351 with that trans
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2014 at 4:08PM
thanks!
~Bryan
67falcon
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:46AM
Just throwing this out there.  Why not get one that already has a 351W?  They are in abundance out there.
If you're still gonna pursue it, find a F150 or Bronco with 351W that you can pull and use.  It will have everything you need to transplant.
Edited by n2fordwagons - 21-November-2014 at 12:48AM
Jeff
71 Torino Brougham
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 1:51AM
i want this one because it has a 6 inch lift, 35in superswampers, another new set of mud grips, alot of new parts, a fastback rag top for the back (plus hard shell), and it runs and drives....800 bucks!.....i wont know until like a week before i could get it.....and if i can find a parts one with a 351, i would use it....but i was told the 300 i6 has more torque than a 302? so i might leave it in for a while until i can find a 351, or just wait til i find a parts one with a manual tranny.
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 3:40AM
Ah.  I see.  That sounds like a great deal.  Yes, the 300 I6 is a workhorse.  If it's running good, there's no immediate need to replace it.
I'd love to get a ragtop for our Bronco.  We've got a '96 with a 351W.
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 4:03AM
You'll love that 300. Great engines that will always run if they have water, fuel, spark and oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 4:28AM
awesome! im wanting to buy it for offroad events and such...i think i might keep the i6 for a while, put in a hei dist, maybe a new carb. but eventually, i will want a 351.....hopefully i get it. ill post pics if i do!
Edited by Grantorinosport351 - 21-November-2014 at 4:28AM
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 4:31AM
do they make performance parts for the 300?
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 9:46AM
Depends... What year.
300 is a very durable engine with a LOT of low end toruqe
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 11:54AM
FORD 300 6=8 Cast Aluminum "STREET & s\Strip" Intake Manifold
Price: $319.00
Shipping Weight: 18.00 pounds
Code: 43-4502
With your choice of:
2 Brl Carb Adaptor
4 Brl Carb Adaptor
Redline TBI Adaptor
Howell TBI Adaptor
Fittment: All Ford 240/300 cid. Description: Our Ram Flow Manifold is a single 2 or 4 brl. carb design, making it Clifford's most versatile manifold. It has an open plenum, allowing the user to mate a 2 barrel, 4 barrel or fuel injection system by changing carb adaptor. Weber 38/38 use 08-1013 Holley 390/or 500 Edelbrock carb , use 08-1014. Click on the adaptor of choice when ordering online. This manifold is made of cast aluminum and is a street or competition style for performance. The true beauty of this manifold is that it works exceptionally well on the street, thanks to our water heated passage along the bottom of the manifold. No matter where in the world the user is located, the water heated passage is a must for daily street use. By using a water/coolant mix to heat the manifold, we can atomize the fuel without boiling it, creating a consistant running engine. This manifold requires a minimum of 350 cfm, and will not bolt onto your engine with the factory cast iron exhaust manifolds. Please do not plug the water jackets and start your engine. Aluminum melts at 450 degree's. *Do not bolt any stock carb to this intake. It has oversized runners and will need an upgraded 2 or 4 brl carb.
Edited by dave302 - 21-November-2014 at 2:09PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 11:58AM
43-4650 FORD 40-300 Dual Weber Carb KIT.
43-4650 Ford 240-300 Dual Weber Carb KIT.Price: $1,389.00
Shipping Weight: 45.00 pounds
Fitment: All Ford 240/300 cid Description: Dual Intake, 2 38/38 Weber carbs, air cleaners, fuel regulator, 2 08-1013 carb adapters and linkage for std or auto trans. Kick down not included with linkage.
Edited by dave302 - 21-November-2014 at 12:23PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:01PM
53-0015 "6=8 HEADERS" Ford Trucks/Cars/Vans 1980-97 2&4wd nPre 1980 2 wheel drive only
53-0015  Price: $359.00
Shipping Weight: 30.00 pounds
Fitment: All 1980-90 Ford Trucks 240/300 cid 2wd & 4wd. Description: This is a shorty street rod header which includes the header gasket and street hookup kit. Average gains on a stock engine are 18-22% when bolting on this header. We have found great performance gains and a throaty muscle car sound when using 2 1/4" exhaust pipes and dual 3 chamber mufflers. The 3 chamber mufflers will reduce the resonation inside the cab. Want more power? Try using our X pipe (Part # 09-0250) and gain 6 to 10% more power!!!
Edited by dave302 - 21-November-2014 at 12:25PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:03PM
1965/96 Dual Headers 2WD/4WD Ford 240/300 Trucks
1965/96  Dual Headers 2WD/4WD Ford 240/300 TrucksPrice: $439.00
Shipping Weight: 30.00 pounds.
Code: 53-0960
Fitment: All Ford Trucks 240/300 cid 2wd & 4wd. *1991-up EFI engines. To use this header, you must move your catalytic converter back for clearance. Description: This is a full length header which includes the header gasket, header bolt set & street hookup kit. 6=8 Headers are made with lazor cut 3/8" flanges, 1 5/8" 16 gauge steel tubes & 2 1/2" collectors. Average gains on a stock engine are 18-22% when bolting on this header. We have found great performance gains and a throaty muscle car sound when using 2 1/4" exhaust pipes and dual 3 chamber mufflers. The 3 chamber mufflers will reduce the resonation inside the cab. Want more power? Try using our X pipe (Part # 09-0250) and gain 6 to 10% more power!!! Fuel injected Trucks can use this header if the catalytic converter is moved back for clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:05PM
63-0144 FORD 240-300/4.9 Header/Intake Gasket
Price: $20.00
Shipping Weight: 3.00 pounds.
Fittment: All Ford 240/300 cid. Description: Gasket designed specifically for use with headers. This has all the intake and exhaust port on one gasket and is made 1/8" thick to ensure a great seal.
Edited by dave302 - 21-November-2014 at 12:50PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:07PM
43-4176 FORD 300 "VALVE COVER" CAST ALUMINUM
Code: 43-4176
Price: $299.00
Shipping Weight: 12.00 pounds
6=8 Cast Aluminum Valve Covers: Made to complete your engine upgrades with great looks and reliability. Kit includes Valve Cover, Gasket, Glue, Air Breather, grommet, black oil cap& instructions. It also has room for roller rockers. Will not fit with EFI system. Carb only please.
Edited by dave302 - 21-November-2014 at 12:32PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:09PM
Ford 240/300 Combination! Header/Intake/Weber Carb Kit
Code: FordCombo
Price: $1,257.00
Shipping Weight: 60.00 pounds
The 6=8 Kit includes: 6=8 Dual Truck Headers/Header Gasket/Street Hookup Kit. 53-0960 Header Stud Kit 6=8 High Flow Intake Manifold W/Water Jacket 43-4502WH Redline Weber 38/38 DGAS (2) Barrel Carb W/Electric Choke 08-7038- Air Cleaner, Linkage kit, Fuel Regulator, 6=8 Adaptor, Gaskets/Nuts/Bolts. Your new Weber carb is set up from our warehouse and ready to bolt on and go.
Edited by dave302 - 21-November-2014 at 12:33PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:11PM
32/36 DGEV Twin Weber System
Code: 3DTWS
Price: $1,289.00
Shipping Weight: 50.00 pounds
6=8 Ford 240/300 32/36 DGEV Twin Weber System includes: 6=8 Dual Carb Intake Manifold W/Water jackets. *This is the first of it's kind available for your Big Ford. (2) 08-1013 Weber Carb Adaptors (2) 08-7033 Weber DGEV Progressive Carbs (2) Redline Air Cleaners (1) Dual Regulator Your new system will be set up with linkage and ready to bolt on, out of the box.
Edited by dave302 - 21-November-2014 at 12:37PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:13PM
Ford 240/300 6=8 Combination
Code: F
Price: $1,257.00
The 6=8 Kit includes: 6=8 Dual Shorty Truck Headers/Header Gasket/Street Hookup Kit. Header Stud Kit 6=8 High Flow Intake Manifold W/Water Jacket 43-4502WH Redline Weber 38/38 DGAS (2) Barrel Carb W/Electric Choke 08-7038-K, Air Cleaner, Linkage kit, Fuel Regulator, 6=8 Adaptor, Gaskets/Nuts/Bolts. Your new Weber carb is set up from our warehouse and ready to bolt on and go
Edited by dave302 - 21-November-2014 at 12:36PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:41PM
To see the company that sells all of these parts and more Click Here.
Edited by dave302 - 21-November-2014 at 12:47PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 12:56PM
To see another company that sells performance engine parts for the 300 engine Click Here. Some of ther parts for sale are listed below.
Product ID: DUI-300-CIK
DUI Complete Ignition Kit - Big Six
Details:
Save $10 by ordering the complete DUI Ignition Kit, which includes the DUI Distributor, Custom LiveWire set, and Billet Wire Looms. Please designate the cap color and wire color when ordering. see DETAILS for more information.
NOTE: We highly recommend reading our Tech Article on "Preventing Premature Distributor Gear Failures" before you install your new distributor.
Cap Color:
Black, Blue or Red
Wire Color:
Black, Blue, Red or Yellow
Loom Color:
Natural or Black Anodized (+$7.00)
Price: $495.00
DUI-300-CIK
Product ID: DUI-300-DZY
DUI Performance Distributor - Big Six
Details
Manufactured by Performance Distributors, the DUI dizzy is the only one-piece, high performance ignition system available for your inline six. Requiring only one 12V hot wire for hookup, it is a clean and simple (drop in) performance modification. See DETAILS for more information.
Cap Color:
Black, Blue or Red
 Price: $365.00
DUI-300-DZY
Product ID: FSP-300-EFK
Stainless Steel Bolt Kit
Details
This 167 Piece - 6 Point Hex Head Bolt Kit is available un-polished or polished (extra), and fits Ford 240/300ci engines. See Details for more information.
NOTE: Always use an anti-sieze lubricant when you install stainless steel bolts or studs. Kit includes one 10 oz tube.
Finish: Un-polished or Polished (+$30.00)
 Price: $84.95
Edited by dave302 - 21-November-2014 at 3:42PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 1:43PM
back in the day they used to cut a cylinder off each Cleveland head & weld them back together as a 6-pop
there's a kinda weird 'underground' for aftermarket high perf 4 & 6 parts, heads, blocks, not sure what's out there for the Ford 300?
but it's not from the usual sources, definitely off the beaten path
Edited by Rockatansky - 21-November-2014 at 1:43PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 2:08PM
i used to have that clifford manifold, sold it at a swap meet for $40 Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 2:28PM
thanks alot guys!!.....btw its an 82 bronco, and im pretty sure its the original engine.
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2014 at 3:01PM
thanks alot guys!!...btw its an 82 bronco, and im pretty sure its the original engine.
Your Welcome. Yes, some '82 broncos had came from the ford factory originally with the 300 engines installed in them. You might also be able to find some good used aftermarket performance engine parts for it.
Edited by dave302 - 21-November-2014 at 3:08PM
This page was generated in 0.156 seconds.
