  New Posts New Posts RSS Feed - Fuel issue....
Fuel issue....
formulacc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote formulacc1 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel issue....
    Posted: 17-May-2018 at 6:00AM
Since putting the Cougar on the road, I've encountered a problem with filling the tank....I can get it just over 1/2 tank before it spits fuel back up the filler pipe...the sender was replaced before I got the car, and it does move in a linear fashion from the just-over-1/2 down as I drive the car....is it accurate though???...dunno...but I feel like it's a vent issue in the tank, as the filler pipe enters the tank roght at that 1/2 full area...soooo, does anyone have a diagram of the tank/vent/lines for a 77-79 Cougar??  according to Spectra (tank supplier), my tank has no internal vent tube, so I'm guessing there must be SOME type of vent in this thing....any help would be MOST appreciated, including values to measure the accuracy of the gauge....
1978 Cougar Midnight/Chamois
Adam
Remember: no matter where you go, there you are.....
lynchster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2018 at 12:14PM
Don't have a clue but I did have that problem with a 79 Ranchero I had owned.
72 Gran Torino Sport
91 F-150
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2018 at 1:17PM
If the Cougar has a fill hose configuration like a '79 Ranchero, there is a hose that ties back into the filler neck that helps with "spit back", but there is also a vent that is on the top center of the tank. This vent, if bad, can be replaced with one from an '80 F-series truck(gas model of course). I believe the top vent line runs all the way forward to the passenger side charcoal canister/filter, I cut this hose and just vented mine with a piece of 1/4" hose that exits on the aft portion of the fuel tank just behind rear bumper. No issues with spit or burp when filling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote formulacc1 Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2018 at 7:59AM
It turns out the gauge is accurate....when the gas pump kicks off, if I slow the flow down, I can fill the tank....but boy is it SLOWWWWW......still, I can deal with that rather than dropping the tank....an extra few minutes at the gas pump won't kill me.....
Adam
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2018 at 10:41AM
Same issue with both my 'birds.  Try this; when your filling up, use only the first notch on the fill holder. It doesn't spit up as hard, and fills more completely.  To top off, hold the handle up(nozzle down against the inside of the neck), and angle it towards the back of the car.  fills up completely, and no gas on the paint/shoes.Thumbs Up
John
79 Thunderbird Heritage
79 Thunderbird Town Landau
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2018 at 12:48AM
Had same problem now an then on ltd2. When I removed the smog system I found the charcoal filter was full of gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote formulacc1 Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2018 at 2:29AM
Originally posted by 7T9_Tbird 7T9_Tbird wrote:
Same issue with both my 'birds.  Try this; when your filling up, use only the first notch on the fill holder. It doesn't spit up as hard, and fills more completely.  To top off, hold the handle up(nozz0le down against the inside of the neck), and angle it towards the back of the car.  fills up completely, and no gas on the paint/shoes.Thumbs Up
It's funny you say that about turning the nozzle 180 around....I used to do that with a Javelin I had....been so long I had forgotten that trick!!  I'll give that a go next time I fill up.....
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2018 at 2:52AM
Sounds like your filler tube is:
1.kinked or twisted
Or
2. Not angled downward all the way, creating a dip that fills up with gas and acts basically as the drain trap under a sink or in the toilet.
Been there enough times with numerous vehicles.
Dfox
Edited by hogfiddles - 19-May-2018 at 2:57AM
1973 Gran Torino Sport - Q code
numerous mid-80's Yamaha XJ-Series (5 trophies and counting)
