Auxiliary Tranmission Cooler |
Posted: 12-October-2018 at 1:57PM |
Thanks for the pics Rock. I will probably install something, just want it to look clean and somewhat factory like. I have installed stacked plate coolers in the past with the cheesy metal brackets they come with. They worked fine on a daily driver/work vehicle, but I want something nicer for my Torino.
no pics, not sure i still have the coil but i might, buried in the pile? i remember the coil is a 'double pass', it spits the flow and runs 2 parallel circuits from top to bottom then they rejoin together. i just cut the tube between where they rejoin and the A/C fitting for a simple hose on tube connection with double clamps. does this pic showing the magnetic inline filter count? Edited by Rockatansky - 09-October-2018 at 6:22AM |
You used a A/C condenser as a trans cooler? I didn't know you could do that. Have any pics?
I have always run it back through the rad afterwards too when I have installed coolers in the past. I figure it's also helpful with the colder weather we get up here.
i used the factory mounted A/C condenser in the front of the radiator, then i ran it back through the radiator to establish & maintain a steady operating temp. blow the excess heat off & stabilize ;) |
I am wondering how many here have added an auxiliary transmission cooler? I am thinking of adding one to my car. I am just wondering what you guys are running? If you're willing, please share some pics of your setup.
