  New Posts New Posts RSS Feed - How do I repair a paint damage
papa scoops View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papa scoops Quote  Post ReplyReply Direct Link To This Post Topic: How do I repair a paint damage
    Posted: 03-November-2018 at 7:12AM
the paint is most likely a repaint. the texture and cracking indicate a harder than normal "enamel" poss clearcoated paint. don't waste your time trying to do it yourself, have a professional do it. your car is much to nice for a do it yourself job. phred
phred
schluese View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schluese Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2018 at 11:04AM
I think this URL
http://paintref.com/paintref/index.shtml
is very nice for everyone, colorcodes not only Ford
Post Options Post Options   Thanks (0) Thanks(0)   Quote schluese Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2018 at 4:27AM
Thanks a lot.
The original blue paint reacts very easily to thinner, the silver color donĀ“t.
In Germany we have only one word for "Farbe" it means color and paint.
My problem is the structure of the paint.
Color is 1G silver on the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2018 at 1:49PM
Do the body supply shops there have a paint scanner? That might help match the paint more exact that just using a colour code.  I agree with John, probably not lacquer, and definitely not if it's original paint.  GM used lacquers, not Ford (at least to my knowledge)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2018 at 1:46PM
i doubt its lacquer! more than likely it's acrylic enamal if it's the original paint
Post Options Post Options   Thanks (0) Thanks(0)   Quote schluese Quote  Post ReplyReply Direct Link To This Post Posted: 11-October-2018 at 10:10AM
I need to know if it is Acrylic Enamel or Acrylic Lacquer.
I readed that Ford never used Acrylic Lacquer. Acrylic enamel would be better for me to paint the damage because there would be no problems with der european Colors.
Edited by schluese - 11-October-2018 at 10:17AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote schluese Quote  Post ReplyReply Direct Link To This Post Posted: 11-October-2018 at 2:31AM
oops, The Pic ist big
Thank you for your participation, but fortunately it's just a small damage
Post Options Post Options   Thanks (0) Thanks(0)   Quote schluese Quote  Post ReplyReply Direct Link To This Post Posted: 11-October-2018 at 2:29AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 11-October-2018 at 12:59AM
Sorry to hear about the damage. Try here for paint code and/or color selection, should be of some service:
Also replied on ranchero.us, good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote schluese Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2018 at 10:33PM
CryCryCryMy 77 Ranchero was attacked sneakily by a garden gate. :confused:Ouch:eek:
Now I want to fix the damage and heard that colors have been used in the US in the past (thermoplastic paints?), Which are not compatible with the modern colors in Europe.
However, Ford should not have used these. Is that correct?
Greets from Germany
