Lokar kickdown for C6 / Edelbrock carb |
Posted: 10-November-2018 at 7:00AM |
here's how mine is mounted with the 450 holley that was on my car (running a 600DP now) lokar for an AOD
texanrebel
Senior Member Joined: 13-June-2018 Location: Houston, Texas Status: Offline Points: 208 |
OK - thanks for the info....appreciate it.
1972 Montego GT
1977 Mercury Monarch 1988 Ford Thunderbird Turbo Coupe |
I am not familiar with the Edelbrock style carbs. Like John said there is an adaptor for the Holley carbs, so there might be one for an Eddy. When I did my carb swap, I was able to use the factory kickdown rod. They bend easily, so I just tweaked it to work with my new carb. No adapter needed.
not sure on the edelbrock? but there is a bracket that goes on a holley to correct the ratio of pull on the cable...
texanrebel
Going in a 72 Montego GT - never installed one before, pretty simple straight out of the box or is there other parts etc...that I will need? Thanks everyone!
1972 Montego GT
