Limited slip differential |
Post Reply | Page 123> |
Author | ||
fordismyboss
Senior Member Joined: 05-January-2014 Location: SF Bay Area Status: Offline Points: 397 |
Posted: 25-June-2020 at 2:49AM |
I went with an Eaton tru-trac on my 28 spline 9" with 2.75 gears. made a massive difference!
Markb73gtorino
Member Joined: 23-September-2018 Location: Corpus Christi Status: Offline Points: 78 |
Speedwaymotors.com
There is a core charge but they have bolt on ready to go 3rd members
marian601
Member Joined: 31-May-2010 Location: poland, europe Status: Offline Points: 62 |
Dear All,
where to buy inexpesive third member with locker, posi trac etc.? I have 28 spline 9". Any additional info needed to choose proper third member?
2015 skoda octavia vRS-wife's car
'99 audi TT quattro 225HP-wife's toy Gran Torino Sport fastback 351C-getting closer :) DUCATI scrambler 803-new toy :) |
rancheromac
Member Joined: 12-August-2013 Location: IOWA Status: Offline Points: 58 |
sorry ! I could not see you already replied again so sorry!
rancheromac
that's what I have. 357 gear I think. I put synthetic gear lube castol in. do I need to use a modifier ? thanks
I used one bottle in my rear diff when I changed it last.
MrSmog
Senior Member Joined: 21-January-2016 Location: Ky Status: Offline Points: 1407 |
I always double whats suggested, cheap insurance.
rancheromac
how much do you add ? thanks
Yes, you still need the friction modifier. It's for the clutches, keeps them from chattering. I got mine from the Ford dealer, it wasn't expensive and it worked great.
rancheromac
I did use castrol synthetic. isn't the friction modifier to reduce foaming?
yes,
you can use the trans x brand available at most local parts stores |
several times i've tried using limited slip type gear lube with the additive already in it, i had to add more additive there just wasn't enough in the store bought oil. Yes clutches need friction modifier
rancheromac
sorry if duplicated. I have this setup , clutch pacs, do I need to use friction modifier? using synthetic gear lube. any other info helpful as I have only run w/351m, know I am doing a built 460. thanks
rancheromac
clutch packs in this rear end. that's what I put in my 9inch. 3.57 do I need to use a friction modifier in this ? I have only run with the 35m that came with car. I know am putting a 460 swap into thanks for any advice on the eaton
"senior citizen" edition
Pinks...
Markb73gtorino
You guys are funny
it was, until it wasn't as i recall the old man with the cane got me a 2nd time at the light |
You must live in a small town. A VERY small town.
2.75:1 gears been there done that in one day i got passed by the street sweeper, ice cream truck, a little girl on a tricycle and a man with a cane |
Markb73gtorino
I am leaning that way so I can learn to crawl before I walk or run. For me I see it like I am in school, you guys and the internet are the teachers and my Torino is the class/homework.
that's what i did on my torino... i had 2.75's that were good, so i had my differential guy set them up on the new LSD with new bearings and seals, and new bearings on the original axles ( then i swapped housings to the lincoln mark 5 with rear discs using the lincoln axles and bearings and housing then just placed my 3rd member section into it after the swap)
Markb73gtorino
Thanks again, also if I leave the ratio at 2.75, where it is now, and install a LSD, then the job would be easier. Food for thought I guess
Rons73
Member Joined: 22-November-2018 Location: Alberta Status: Offline Points: 146 |
Maaayyybeee....
I believe there is threaded rod, scrap metal, and a BFH too.
Markb73gtorino
Sounda like very good advice. I may just get a new 3rd member and call it good. I always need more tools so setting up my garage with what I need first may be the right call before I dig into a project like this. Thanks again
handsofstone
Senior Member Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3946 |
I bought a harbor freight press for when i do my control arm bushings and differential. Ended up just doing a reseal on the rear. If you get the press, buy the heavy plates that will let you press the new bearings on. Wear glasses and stand off to the side.
