  New Posts New Posts RSS Feed - Door Panels
Door Panels
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: Door Panels
    Posted: 13-January-2021 at 11:10PM
Contacted Ron Miller at AutoKrafters about the issue with the Distinctive Industries 72-76 door & rear trim panels and he said the problem is NOT QUALITY but delivery... there is a 6-8 delivery backlog at DI. Ron said they aren't taking orders right now until the backlog is caught up, but with Covid, that may be never! Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2020 at 10:48AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2020 at 10:47AM
A buddy of mine got his from Dearborn Classics....
and he said the only thing he had to do was reuse the steel upper backer panels from his original trim panels... no mention of arm rest issues.
Here are the panels offered by Distinctive Industries (http://distinctiveindustries.com/) for the 72-73 (thru 76) Torino...
the twin chrome bands are factory for the 72-73 Torino but not correct for the 74-76 Gran Torino. A bit of custom work and they could be made to appear OEM.
I believe these are the panels all the Ford aftermarket suppliers sell....
eljzak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eljzak Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2019 at 2:29PM
They did not recommend anybody because the said they have the largest data base of suppliers. So basically you need to go to a upholsterer
ELJ
torinomike650 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Posted: 29-March-2019 at 12:22PM
Where did they recommend getting new door panels from? I'm looking to replace all 4 panels in my'76 Gran Torino and was going to get the set from Dearborn Classics...
--Mike
1974 Ford Gran Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote eljzak Quote  Post ReplyReply Direct Link To This Post Posted: 29-March-2019 at 10:17AM
Sorry for the delay in response.... Auto Krafters were the best in explaining why they wouldnt fit. They told me it was because of the arm rest. The said if your arm rest measures 10 1/2 inches total length. they would fit. The gran torinos measures 14 1/2 inches total because of the plastic base behind it. So the hole were the door handles align are is wrong.  Also they said you would need to change the back panels as well because the stitching will not match
ELJ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2019 at 1:31PM
a good upholstery shop should be able to make
 you some using your old ones for the metal upper and the vinyl for a pattern
you can buy the repop "fuzzys" for the top by the glass
Post Options Post Options   Thanks (0) Thanks(0)   Quote eljzak Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2019 at 12:33PM
Yes basically.  But I like your straight to the point approach then my 20 minute explanation on the phone
ELJ
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2019 at 11:14AM
HAHAHAHA LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2019 at 11:10AM
Sounds like some interesting calls. Something like this?
You - "Hi, I'm calling about the door panels for Torinos…"
Them - "Yeah, we sell them, but they suck. Don't waste your money."
You - "Thanks for the warning."
Post Options Post Options   Thanks (0) Thanks(0)   Quote eljzak Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2019 at 9:59AM
Thankyou for the post. I called both places and they  both did not recommend purchasing.
ELJ
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinomike650 Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2019 at 6:21AM
Front: https://www.dearbornclassics.com/ranchero-torino-front-door-panels-standard-1972-1976.html
Rear: https://www.dearbornclassics.com/torino-rear-side-panels-formal-roof-1972-1976.html
Both sold as pairs, from either Dearborn Classics or MAC's Antique Auto Parts.
Keep your old panels and remove trim to place on new panels. Also BC these reproduction panels don't fit as well as the factory ones, so some modification may be needed. Maybe someone else who's bought these panels can chime in and let you know what they've done to get them to fit?
Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote eljzak Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2019 at 4:14AM
Hello Everyone. New member here from New York. I am looking for the door panels for my 1976 Starsky and Hutch Original from the factory Car. Mine have speakers cut in and wanted to put it back to original. Any Idea were I can purchase them... Regards Erik
ELJ
