  New Posts New Posts RSS Feed - New member  Steering column question
JohnGT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Topic: New member Steering column question
    Posted: 14-April-2019 at 1:56AM
Hi All, Glad to be on board. I have a 71 Torino GT convertible 351C 4v auto. Looking for advice on removing the flange casting from the steering column. Lock cylinder is out, turn signal switch out, nuts off tbolts and snap ring off, but flange will not budge. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2019 at 2:24AM
not sure but if it's like the 72-79 columns i think here's a hole for a socket to fit in to remove a bolt for the shift tube IIRC but i believe the upper casting comes off with just the 2 nuts/t-bolts...
 maybe someone else here is more familiar with the 70-71's
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2019 at 2:25AM
oh and welcome! BTWBig smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2019 at 9:38AM
Welcome to the forum.  I believe the 70-71 column is similar to the 70-73 Mustang column, but it is different from the '72+ Torinos.  That said, I think John is on the right path about the T-bolt nuts.   Is your car a floor shift or a column shift?
These diagrams might help:
This article may be helpful too, it's got lots of great pics:
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2019 at 11:43AM
Thanks for the welcome and the info. I have a column shift, and have been going by the shop manual. Just took a quick look at the article you shared and will study that closer. Almost seems like there might be some mechanics trick to help remove it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2019 at 1:03PM
Sounds good. Let me know if you need anything else. I can dig into the parts catalog for some diagrams to help too. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2019 at 6:44AM
Hey I'm back, still no luck. Possibly the bushing not releasing from the shaft? Tried tapping the shaft lightly while pulling the flange with no result. Really stumped. Any other ideas? Thanks much!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2019 at 10:51AM
hmmm IDK.
 is it a tilt column??? they are configured a little differently sometimes...
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2019 at 1:31AM
No, fixed column.
mean steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2019 at 3:43AM
If everything is out like you said, it should slide off. If it's just sticking on the bearing it should only take minimal force to release it. With it in the car it will be harder to try and tap it off. Wouldn't hit the shaft. Wouldn't want to ruin bearing at the bottom, or shaft threads. I would try a ghetto slide hammer setup. I've used rope/string and tied it to a slide hammer so as to not mar the part.
Like I said, if the bolts are out and snap ring off, shouldn't need much force.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2019 at 6:19AM
I think Steve is correct on this one.  It sounds like you have everything disconnected as it should be, so it must be hanging up on something. You could snap a pic of the column and post it here to make sure you didn't miss something.  Otherwise, the slid hammer would probably work well, or rigging up a puller might work too.
You could also try reaching out to a steering column specialist for help.  Here's one I found through a quick Google search:
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2019 at 10:14AM
Thanks guys, Steve's idea about the slide hammer gave me an idea to try a steering wheel puller rig. Using it with zip ties, no luck yet and afraid to ruin the bearing if I put too much on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2019 at 10:39AM
that basically looks the same as 72+ IIRC you'll need to take the ignition switch loose so the actuator rod can come off with the upper barrel?...
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2019 at 10:45AM
Sounds worth a try. Gonna be a couple days before I can back to it. Thanks all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 29-April-2019 at 12:50PM
Remove the Phillips screws at the top and remove the steering wheel lock. There is a spring back there so it might shoot out. That's also connected to ignition switch rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 29-April-2019 at 4:50PM
On second thought, I'm stupid. That can stay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2019 at 9:30AM
Have just continued working it and tapping the shaft. Flange is coming forward slowly, but socket casting seems to be coming with it, which I don't think is supposed to happen. What am I going to damage if I keep going?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2019 at 10:23AM
Disregard last post. Flange is off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2019 at 11:33AM
Ok, now that it's off I have a couple new questions, big surprise right? Appears there is a broken snap ring on the shaft behind the flange, photo attached. Manual doesn't mention a snap ring there, but am I correct that there should be one? Also, any recommendations for lube/grease for the upper actuator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2019 at 1:11PM
Some new grease will make things smooth on assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2019 at 4:56PM
IDK white lithium grease???
Post Options Post Options   Thanks (0) Thanks(0)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 4:09AM
No snap ring that far in. The only one is behind turn signal switch. It looks like the shaft bearing came apart and left a piece ( race) ceased to the shaft. Should slide off and would explain why it was so hard to disassemble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 12:04PM
that's kinda what i thought, but i just reexamined his above pic... look dead center of the pic, in the shadowed area... i see the ends of a snap ring with the 2 holes on the ends of itShocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 2:11PM
another possibility is a c ring.  It moves around the shaft in the groove. Ends don't really appear to be broken off. Here's another angle photo. Won't be able to get back to it until the weekend to see if it's a piece off  the back of the bearing race.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 2:13PM
same photo sorry. Trying again....
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2019 at 2:20PM
I am going with shim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2019 at 3:20AM
I see the c clip now. Dosen't look damaged or anything but I have no idea what it's for. Not sure if there is a retainer at the other end of the shaft, but maybe it keeps the(and I'm totally just pulling something out of my) shaft from sliding up into the car.
Just out of curiosity, what are we digging into this thing for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnGT Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2019 at 4:10AM
I had a new top put on late last fall, but hadn't seen it in the daylight as I had to pick the car up after dark.  A couple days later when I could get to it, the weather had turned very cold, 0 F, and when I tried to start the car the ignition was very stiff turning, so bad that I was concerned about breaking something. The only thing that changed since the prior start was the weather, and it felt mechanical, like it was gummed up.  Now that the weather is warming up I wanted to take this apart to see if there was something broken.  Everything appears to be fine, but as you can see from the photos there's a lot of old grease and   grime built up. Hopefully that was the problem, but taking that flange off became a project in itself.   Hoping to put everything back together this weekend now that I have it cleaned up.  I sure do appreciate all the help you guys are giving me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2019 at 2:31PM
Ok. Good to know that the issue you were having is figured out. I concur. Grease looks original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2019 at 2:48PM
ok makes sense now! i like power punch grease myself! but and light grease should be fine also check the lower rod to the ignition switch to see if its rubbing anywhere i've had that happen and it would want to stick between start and run...
This page was generated in 0.093 seconds.
