Clamping designations |
Green Hornet
Member Joined: 03-May-2019 Location: Dresden Status: Offline Points: 45 |
Posted: 12-June-2019 at 8:56AM |
Thanks. This is exactly this what I need.
doc76251
New Member Joined: 08-June-2019 Location: VA Beach Status: Offline Points: 7 |
I think we are getting lost in translation. Clamping designations may mean Terminal designations on the gauge cluster plug. Add into the mix that there are a couple different cluster plugs in that era 14pin, 15 pin and 18pin (IIRC and I'm probably wrong). My 77 Chero has a 14 pin connector block to hook up the instrument cluster. Cheers, Doc
NeillNZ
Member Joined: 27-June-2016 Location: Wellington, NZ Status: Offline Points: 40 |
Could this be what you need? This is from 1972. |
It appears to be a system of designating circuits on a wiring diagram, and appears useful, until they declare that the designations need not be marked on the actual wires. Makes for wonderful process diagrams that are next to useless.
Green Hornet
This is Our DIN Norm for some clamping designations..
I have all original circuit diagrams. My problem lies in being able to read the individuell terminal designations .
Green Hornet
Admin Group GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5854 |
Otherwise, you just need a wiring diagram. The link I posted above is the 1973 Torino wiring diagram. It's not the factory one, but it's still very good. You can buy a factory one off eBay: You can also get a universal wiring harness if you are rewiring the entire car: Or you could try to find good used wiring harness from North America and have them shipped to you in Germany. Hopefully this helps. |
T-Bird_79
Member Joined: 05-May-2017 Location: Riga, Latvia Status: Offline Points: 103 |
Get factory wiring diagrams (here or on Ebay) they will give You all the information You'll need-locations of connectors, wire colors, wire locations in connectors etc.
Andris
1979 Ford Thunderbird 1977 Opel Commodore Coupe Euro personal luxury car 1969 Vauxhall Viva small American 1989 Opel Kadett GSi 16V known as Pontiac LeMans 1978 Moskvitch 412 Soviet rally |
Green Hornet
For example. The clamping designation for the Ignition is 15 in Germany and 16 in the USA . So I need the other complete clamping designations. For the Front an Back Lights, for the alternator, for the battery . . .
yeah vince i think he's asking about a schematic... not sure about DIN and ISO????
I don't really know anything about clamping designations and don't think you really need them to fix or re-wire a Torino. Are you redoing all of the wiring in your car? We do have a wiring diagram here on the website that might be helpful for you: http://grantorinosport.org/librarymaintenance.htm If you ask specific questions and post some pictures of the wiring you are working on, I am sure some of us can help you through you project.
Green Hornet
I want to install the complete electrical Wire. So I need the Importent clamping designations! For example Ignition, ground, the lights ..
Can you get more specific on what you are looking for? What wiring are you trying to repair?
Green Hornet
Hallo.
I've an 73 Ford Gran Torino. I come from Germany. Our DIN Standard is a different from the ISO Standard. My problem is reading the american electrical clamping designations! I know only the German electrical clamping designations. Can someone send me a list of the individuell terminal designations ? Thanks
