Electrical topic |
Posted: 01-May-2021 at 6:45PM |
look for the 194LL (Long Life)
Gazoo2
Member Joined: 14-September-2010 Location: Calgary,Alberta Status: Offline Points: 63 |
The w5w has the same size base as a 194, but the w5w is brighter and runs hotter. It was causing heat damage to the socket in my European car so I changed to 194s to prevent damage. The 194s are bright enough.
72 GranTorino "rat wagon" 351C, a work in progress
69 Mustang Mach 1, 351w, Borg Warner T5, rack & pinion steering, fuel injected |
Admin Group GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5854 |
I am not sure if that bulb you linked to is correct. It appears correct, but I don't know if the specifications are the same as a US bulb. The side markers use a 194 bulb, which is once like this:
Compare the specs to the European variant, and if it is the same it should work. Or just order them from RockAuto. As for the nylon nuts, I don't know of a source off hand. There ware similar ones in my grille I was still able to source from a Ford dealer several years ago.
1976kjell
New Member Joined: 16-August-2020 Location: Harstad, Norway Status: Offline Points: 24 |
Hello
I have some question about the electrical system in 1976 Torino Wagon I have googled, but didnt find any general info about which bulbs to use in those cars. The tail-/flash-/headlights are ok, 21w and 21w/5w, but the sidemarkers was new and "modern" for me Is it ok to use w5w-bulbs in the sidemarkersockets like this: https://bit.ly/3hnob87 Also the taillightassemblys fastenings-"nuts" by plastic are needed. Is there any shop that sells these like the one on this photo, and the related screws? https://photos.app.goo.gl/qoqBufcKB8gQj3Bo9 Link had to be used so far, until my membership is upgraded to "new member"
