  New Posts New Posts RSS Feed - Aftermarket steering wheels - what looks at home?
paj1965 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paj1965 Quote  Post ReplyReply Direct Link To This Post Topic: Aftermarket steering wheels - what looks at home?
    Posted: 23-November-2020 at 6:29AM
I have this one, too.  Love it.  Great size and feel.
My Toy List:
1972.5 Gran Torino Sport
2001 Mustang Cobra Vert
2001 Lightning
2013 Jeep Wrangler
BadHabit351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2020 at 3:55AM
Grant Wheels 9660. It's 15" and combined with my Lares quick ratio steering box works well. It also has enough dish that it doesn't cause your fingers to interfere with the turn signal stalk or the ignition switch. As a bonus; my car is built as period-ish hot rod, so it matches the style of the car.
1973/72 Gran Torino Sport
1971 Torino GT convertilble
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2020 at 1:01PM
That is a tilt column! I had to use that angle to get a decent shot of the steering wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2020 at 12:46PM
Looks like you need a tilt column.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2020 at 10:13AM
I used one from a 1976 Mustang ll. The Maverick, Pinto and Bronco all used this steering wheel as an option.
Post Options Post Options   Thanks (1) Thanks(1)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 19-November-2020 at 6:04PM
This one was put in my car after a 39 year slumber in the basement.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2020 at 4:29PM
I don't know what new issues or details have been found since I did my conversion, in 1988. I bought a Saginaw steering box from a 71-73 Mustang, and sent it off to be rebuilt by the same builder doing NASCAR boxes. I don't think there is any difference in the pitman arm, I used a new one for my 72 Ranchero then.
I learned by phone then that lots of OEM cars had compatible Saginaw boxes in them. In the 80s' a Trans Am was a more common car to find than the 71-73 Mustang, I'd have hunted one of those if I knew before the Mustang I found. The first thing to look for was the number of bolts on the cover visible from directly above. The two bolt type are not a Saginaw box for sure, those all have four cover bolts, that can work. That's all I recall learning back then.
73 Ranchero GT 351C-4V 3.70 gears, to build a keeper
73 Ranchero Sport "72 front end", floor shift/console, planning EFI 351-3V &4R70W
92 Lincoln Mark VII SE, OBDII 347/4R70W
EvilScientistMoose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EvilScientistMoose Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2020 at 2:05PM
I can't comment on the aftermarket wheel, but if you want to improve the steering feel, you need a new steering box.  There are two options, a Lares quick ratio, or swapping to a Saginaw steering box.
I am currently swapping to a Saginaw quick-ratio box in my '76 Ranchero (the original is a two-bolt Ford), is a different pitman arm also required?
Dubz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dubz Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2020 at 5:07AM
Awesome!  I'll look into that PS swap as well, that would be a great addition.
1974 Gran Torino in flat black 351W/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2020 at 10:17AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2020 at 11:56PM
stock wheel is 14" dia.
 grant #773 is blk 13" GT signature series...
i have a 12" version on my car grant #772
I use this exact wheel on mine, 13" version. Still have the GT horn button, been there for almost 30 years. Jeesh I'm getting old.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2020 at 6:06PM
Dubz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dubz Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2020 at 3:09AM
Hi guys,
My steering wheel is cracked, and the large diameter wheel makes the car a bit harder to get into with my racing buckets.
I think a smaller diameter wheel might be a good move to make the steering feel a bit more responsive, although I'm fairly certain the power steering might be more of the culprit.
Summit suggests a Grant 1902 based on my model/year, but I imagine anything would fit.
What's everyone got?
