  New Posts New Posts RSS Feed - Distributor swap
Distributor swap
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Topic: Distributor swap
    Posted: 11-October-2020 at 4:34PM
The 302 diameter is slightly smaller, I've seen sleeves made to let the 302 cam synchronizer from 96-01 Explorers go into a 351W.
73 Ranchero GT 351C-4V 3.70 gears, to build a keeper
73 Ranchero Sport "72 front end", floor shift/console, planning EFI 351-3V &4R70W
92 Lincoln Mark VII SE, OBDII 347/4R70W
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 11-October-2020 at 12:56PM
Curious on the 302 housing being smaller...
We used to swap oil pump, pump drive, and distributor form 351W into 302/289 engines for durability.
Don't remember housings having a fitment issue...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-October-2020 at 4:13PM
housing height can be different especially across aftermarket mfgr's
BadHabit351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 06-October-2020 at 1:45AM
The Windsor is also the same except for the cam gear on the bottom.
I've never heard that before. Hmmm....
1973/72 Gran Torino Sport
1971 Torino GT convertilble
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
The Torino Kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2020 at 4:27PM
the distibutor from a 429/460 engine is the same as well.
1973 Gran Torino Sport CJ 351
'Q' code 63R body
Rivercrest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2020 at 7:13AM
Thank you, I appreciate the on going knowledge of this forum........
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2020 at 4:00AM
Yes, the distributor is the same for a 351C and the 400/351M engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2020 at 1:23AM
Just wondering if the dist assembly from a 351M is swapable with a dist from a 351C......1974 Vintage.
