  New Posts New Posts RSS Feed - AC CLutch wire problem
Topic ClosedAC CLutch wire problem
bogart2892 View Drop Down
Direct Link To This Post Topic: AC CLutch wire problem
    Posted: 10-June-2009 at 6:58PM
Hello Im working on my ac on my 1973 gran torino 4 door with a 302.  The ac clutch actuator isnt getting a signal for some reason.  The wire looks good.  When I connect a 12v+ wire to it it actuates and seems to work fine.  For some reason when I turn on the ac it doesnt turn on the clutch.  Someone help.  Thanks Jon
baough View Drop Down
Direct Link To This Post Posted: 10-June-2009 at 7:48PM
Sounds like a low charge to to me, or a bad pressure switch.
Former U.S. Navy submariner onboard USS Sturgeon SSN 637
73 Gran Torino,351C,auto
76 F250 4x4, 390
88 comanche
91 explorer
92 bronco
08 Harley 883C, two kids, 4 horses,2 dogs,2 cats,1 lizzard.
Direct Link To This Post Posted: 10-June-2009 at 7:53PM
Is there a pressure switch on that car?  the wire for the compressor goes into the firewall into the cabin.  I cant figure where is goes from there?  I just changed to a 134a system.  The whole ac system works great when I connect a jumper from the compressor to the + battery term.
Torinogts73c View Drop Down
Direct Link To This Post Posted: 11-June-2009 at 6:42AM
   Ford didn't use low pressure switches in 73. You might check out your vaccum mode switch in the dash, could be the micro-switch on there that is bad.
Gary 73 Gran Torino Sport 351CJ,SVT LIGHTNING,07 CHARGER R/T HEMI,97 Mustang GT Vert
"Never complain Never explain"
Direct Link To This Post Posted: 11-June-2009 at 7:08AM
Do you happen to know where it is?  Thanks
Direct Link To This Post Posted: 11-June-2009 at 11:21AM
Low pressure switch was just the first thing that came to mind,  been many years (20+)since I've worked on any ac systems. So what causes the compressor to cycle if theres no switch? looks like it's time for me to start refreshing myselfe on ac sytems.
76 F250 4x4, 390
88 comanche
91 explorer
92 bronco
Direct Link To This Post Posted: 11-June-2009 at 11:50AM
Kind of complex but Ford had a thermostatic device on the expansion valve and a suction throttle valve to keep the unit from freezing up. So the compressor would cycle on or off . The vaccum mode switch is located on the left side of the dash, where it says A/C  Heat etc. there are 4 screws that hold it up to the dash panel. You will see all the vaccum hose going to it. Hope this helps you out!  Confused
