  New Posts New Posts RSS Feed - Toploader Transmission Info Needed
2fst4u View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2fst4u Quote  Post ReplyReply Direct Link To This Post Topic: Toploader Transmission Info Needed
    Posted: 27-September-2019 at 3:33PM
Toploader info needed.
Is the 4 speed in a 72 the same length as the 69-70 torino's or is tailshaft the same length as the Mustang ones???
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2019 at 5:47AM
i will say the the tail housing the same length.the only thing is the location of the shifter.thay sell a plate to put a torino trans in a mustang but you cant do a mustang trans in a torino unless you change the tail housing or cut the car up.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2019 at 6:59AM
David Kee's page is an excellent reference resource
what i see is NO the 69-70 Torino tail is 17" and the Mustang is 14" but you decide
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2019 at 4:32PM
what year/model you putting this trans into?
