  New Posts New Posts RSS Feed - transmissions
transmissions
dougrt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dougrt Quote  Post ReplyReply Direct Link To This Post Topic: transmissions
    Posted: 23-November-2020 at 2:06AM
what years of c6 bolt to 351 cj
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2020 at 3:50AM
C6's came in two bell housing patterns, one for all SBF's and one for the big blocks. The SBF C6 is much more rare, those were mainly in the early 70's. I doubt they made them after about 1974, which meant for a 351W, those weren't "performance" models then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2020 at 10:31AM
They made C6 for F150, with 302/5.0, 351W, and 300/4.9 I6
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2020 at 12:54PM
C6 also has an FE bell often called the 'round' bell
this page says there are 5 different C6 bell patterns
The C6 was used in trucks and cars with larger engines. Five different bell housing varieties exist for use with various Ford engine families:
The Windsor pattern was used on the 300 I6, the Ford Windsor engines and the 351 Cleveland.
The 460 pattern was used on the 351M and 400 and all of the Ford "385" engines.
The FE pattern was used on the FE engines
The rare 66 - 68 Lincoln MEL 462 pattern which was used on 66 - 68 Lincoln Continentals with the 462 engine and also on 68 - 69 Lincoln Continentals with the 460. This pattern rounds off on the passenger side to clear the heat/AC box on the 66 - 69 Lincoln firewall.
Diesel pattern. This was similar to the FE/"385" pattern but the two are not interchangeable.
the Windsor pattern as they are calling it, comes in 2 different styles, smooth round around the top of the bell and a finned version with about 5 fins stretching from the top bolts area to the main trans housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 23-November-2020 at 1:08PM
Funny, I'm getting old and forgetting how many dumb changes Ford made back in the 60's and 70's.
"Let's make a five bolt bell housing pattern, owners will have a hell of a time swapping around engines and transmissions with that."
Ford has had the dumbest engineers working there forever, you cannot count all the dumb things they have designed. I am not saying they haven't had very good engineers, but they have made some of the worst design and planning errors you could think of.
Example, here's what they came up with for exhaust manifolds for a 302 into the Explorers;
Could anyone on their worst day ever come up with something that horrible?
