  New Posts New Posts RSS Feed - trim caulk
trim caulk
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: trim caulk
    Posted: 25-December-2018 at 6:17AM
I am currently working on cleaning up some trim pieces  and need some information.  The roof line drip rails (73 GTS) has what appears to be some type of caulk/sealant in the inner part that goes against the roof rail to seal it.  Does anyoine know what product works best to replace this with?  Mine was mostly all dried up, cracking and missing in many areas after  the trim was removed from the car.  Thanks - Dave
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-December-2018 at 8:09AM
that black messy nasty goop AKA buytl rubber was used a lot  Confused i'd probably go with a urethane seam sealer there may be other things to use too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 25-December-2018 at 1:24PM
Thanks, John, I'll look into that, sure isn't alot of fun getting the remnants out, took a while on the first one.
