  New Posts New Posts RSS Feed - Tubular upper A arms group buy
 Post Reply Post Reply Page  <1 78910>
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-June-2017 at 1:22AM
Nice, so they finally start to produce Leno's arms, albeit on a limited basis!  I like the fact that these correct the geometry, but they are pricey!  Note that they also have lower arms and strut rods.  I am not sure if all will swap over to our Torino though.
Edited by 72FordGTS - 08-June-2017 at 1:23AM
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 08-June-2017 at 4:02AM
I reckon thats a little lie they're telling
they'll probably be more available than they're letting on but "introductory" just means they'll get a few quick sales in a panic buy if any Galaxie owners see them and they're building a racer
Barnaby
BackInBlack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 08-June-2017 at 6:00AM
Originally posted by madmaxtorino madmaxtorino wrote:
hotchkis is making them now but they are 600 loaded.
This is a good sign...means the industry is starting to recognize these cars.
These look great!   They correct 2 problems; the positive caster and the negative camber gain.  These look like they will work with teh stock spindles without any extra stuff.  These a-arms appear to have more arc on the arm to raise the upper a-arm inclination angle without using extended ball joints to lengthen the spindle.
Honestly, these look better and correct the geometry issues vs the Little shop A-arms.  Little shop's are nice but they only increase the positive caster by 4 degrees.   Which is why I'm using Howe Racing upper extended ball joints to help correct the camber gain coupled with the Little Ship upper a-arms.
I would like a better lower arm...still haven't found anything (aside from just welding/boxing the stock lower arm).
Also, still looking for a front 1 3/8" sway bar option.
Hotchkis has a 1 3/8" bar for Galaxy...will it fit the Torino?  Torino sway bars were used on the 65 Galaxy, but can the Galaxy sway bar be used on the Torino?
Edited by BackInBlack - 08-June-2017 at 7:29AM
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 11:28AM
So the the Hotchkis arms will fit a 73 then?
I was putting off buying these til last but it turns out I could use the clearance for the turbo headers.....mocked up today and I can make the pipes much shorter if I remove the big pressed stiffener nearest the block
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 11:39AM
I dont know for certain...I did take detailed measurements of the galaxy spindles vs the torino.  They are compatible.  However, I didn't write down anything on the a-arms for comparison
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 12:30PM
Spindles/knee assemblies are interchangeable 65-78 fullsize into the Torino chassis.
Knee assembly includes upper, lower control arms, spindles and (Supposedly) strut rods.
Some Lower control arms have different spring pockets, so swp in pairs if they don't match or your car won't sit level.
Don't know anyone who actually swapped the struts as the big bolt/bushing combo is a bear to get apart. When we were putting Torino Disc brakes into 65-67 Galaxies, we swapped the control arms because the ball joints looked "different" (bolt-in vs. press-in) and the Torino parts were fairly new, Galaxies typically had 100k or more miles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 3:09PM
I don't have the parts catalog with me know, but IIRC, the same part number was used on the upper arms from for the 1965+ Fords as the 1972 Torinos (early).  The 1972 late - 1976 Torino arm received the larger bushings, but are otherwise the same.  I can't remember on the lower arms, if Randy has done this swaping, it sounds like they are the same.  I'd probably stick with the Torino strut rods to be on the safe side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 12:24AM
Looks like I might have to buy those then!
I'd rather spend the extra $100 on them vs little shop if they fit. It's either this or mutilate the chassis and bring the pipes down rather than up....
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 3:00AM
Thats great info!   I didn't realize these parts were used on so many full-size models.
What about the Galaxy sway bar...will it fit on a Torino?
Torino is really wide (63" track width).  I think I measured 59" eye to eye on the Torino sway bar and it looks like the Galaxy is 58"
The reason I'm asking is that I want to upsize the front sway bar to 13/8"   I'm wondering if I can simply install the Hotchkiss Galaxy sway bar on my Torino.
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 5:50AM
I'm sure summit sell one that size for a Tornio
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 6:05AM
Nope...I've looked into Nearly all fords chevy pontiac...etc.
I can't find anything that will work on a Torino that is larger than the standard Addco 1 1/8" front sway bar.  What makes it so difficult is that these Fords have a very wide track width as compared to other cars.   Chevy is pretty standard ...if my memory serves me...around 60"
Torino is 63"...more like a truck.
This means the sway bar has to be wider.  The only option I found if you want more than 1 1/8" front bar is to custom install a splined sway bar.
I would rather find one that will bolt on...
-John
1973 GTS
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 6:44AM
I've been looking too, for the Ranchero, and came up with the same results. Might go splined.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 8:30AM
Track width on torino is supposedly same as the earlier fullsize (65-68). Never personally measured it.
Torino frame dimensions are so close to Panther chassis as well, I would think you could adapt it's bars.
We always got parts for the brake upgrade at a you-pull-it yard and rather than fight with the Strut rod's big bolt, we would shear the two little bolts that hold it to the LCA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 10:26AM
I would think the best option might be to find something that'll bolt up to the existing points if widened, then weld in some chromoly tubing to widen it?
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2017 at 12:35PM
can't find a bigger bar? or hate to spend the $$$? do what i did on my celica (and my ford courier too) with a little ingenuity and fab work... double stack two stock bars Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2017 at 5:39AM
John, I can check the parts catalog later to see if the bars are interchangeable. I thought that they wouldn't swap, going by memory.
Why do you want to go so big in the front?  Personally I'd like to find a bigger than 7/8's rear bar before I upgraded the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2017 at 8:54AM
Every sway bar I've looked at to "adapt" has not worked out because of the overall width of the mounting points on our torino's.   If you dont land near the same realative mounting points with the "new" bar it causes other interference problems.   That said...I measure stock eye-to-eye front sway bar at 49 1/4", arm length ~12", frame mounts speration at ~38 1/2".   I haven't found anything that will come close.   I did find some more modern bars say from a 2002 camaro or late model charger but the mounting are completely different where they dont use the same stud through an eye on the bar end mounting configuration.
EDIT If my memory serves me...I think the Galaxy bars are 48" eye-to-eye center which is to far off to be able to reuse on a Torino.  I keep coming back to a custom splined setup for the front.
I always felt teh body plows to much in the turns...I want to control the body roll more to help limit the suspension range under compression to optimize the camber gain.  If you add to much rear bar it will oversteer like crazy...I've already tested this with bigger rear bar and stiffer rear springs.  That backend breaks loose way to easy around a corner.
 Trying to keep the balance front to rear I wanted to control it more with the front bar rather than the rear bar.   I've already put the 7/8 rear bar on...and I feel it helped overall but it made the back end break loose quickly relative to the overall body roll.
Thats why I'm thinking a good overall combination would be a 1 3/8" front with the 7/8" rear.   If you look at what some suspension kits offered for chevelles (The are not exact but pretty close in size/weight to our car. I did a analytical comparison via spreadsheet between chevelle/torino for comparison between springs/bars and basic suspension geometry) they tend to be in this ballpark for performance street setups.
Oh...also regarding cutting welding up sway bars.  I dont think that it would be a good idea to do that because they are made from spring steel.   Heating it up would wreck the properties of the steel.   Sway bars are also (or should be) heat treated.   Any heat applied would ruin them.
Double up sway bar!  didn't think of that.  How did that work?
Edited by BackInBlack - 22-June-2017 at 8:58AM
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2017 at 10:52AM
So, welding up the cracks in the sway bar on my truck ("Quality" G. M.) was a bad idea???
Some considerations for a sway bar:
Width hole-to-hole
Mounting location
"arm" length
vertical offset from mounting location to hole location
Edited by Big Bird - 22-June-2017 at 10:57AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2017 at 2:36PM
I'm prolly overthinking it...Analysis paralysis...
I just need to finish it and drive it...see where I'm at then adjust.
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2017 at 3:32PM
John are you still planning on using CVPI springs in the front? If so, I'd recommend trying the car with those springs and a 1 1/8 bar first before you go to all the work of a custom splined bar. Once you get your springs then I'd play with the bars if you need too. With the heavy front Springs in my car in had no issues with oversteer unless I induced it even with the heavier rear springs. I since soften my rear springs for ride and because it was skipping one rough pavement. The car is very flat in the front with the CVPI springs.
Edited by 72FordGTS - 22-June-2017 at 3:33PM
