  New Posts New Posts RSS Feed - Tubular upper A arms group buy
 Post Reply Post Reply Page  <1 91011
simon455 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simon455 Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2018 at 5:44AM
does anyone know where i could find taller upper ball joint for the littleshop a arms?
72 pro touring fastback
BackInBlack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2018 at 5:51AM
I got mine from
http://howeracing.com/
I also figured out a way to use Chrysler lowers in our OEM lower arm to use their extended length lowers.  I haven't really decided on what I want to do regarding the geometry changes.   I was looking at Fatman drop spindles and using 1/2 to 1" extended uppers.   If I stick with stock spindles I was thinking of going +1 extended lower balljoints to lower the car.
I got my uppers from howe....I'm not sure if they have anymore in stock.
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote simon455 Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2018 at 5:58AM
i was eyeing their site, could not see a ford bolt in ball joint? any chance you gotta part number?
Don't belive you need drop spindles, im usning the cvpi front springs with 3/4 of coil cut and car is just
sitting low enough to cover the top of the tire, mind you its a 275 35 19 on a 9.5' rim in the front, stance is really good...
