  New Posts New Posts RSS Feed - Turn Signal Won't Lock Up/Right
SilverSatllion05 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverSatllion05 Quote  Post ReplyReply Direct Link To This Post Topic: Turn Signal Won't Lock Up/Right
    Posted: 01-November-2016 at 8:36AM
Hello all!  I have a 1971 Torino 500.  She's a mess, but I'm getting around to some stuff.  The turn signal lever will not lock up/right, but will down/left.  When up, I hear the blinker noise, but the right arrow doesn't light up.  That's probably just the bulb, as no other lights really work on the gauges.
My question is, is this the part that I need to fix it?
http://www.dearbornclassics.com/67-71-turn-signal-cam-kit.html'
Thanks for your help!
The Random Automotive
Website: http://www.therandomautomotive.com/
Twitter:https://twitter.com/therandomauto
Facebook: https://www.facebook.com/TheRandomAutomotive/
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2016 at 4:28PM
yes i believe so! if it don't lock or feel right.... one of the curved plastic ends are probably broken!
Edited by californiajohnny - 06-November-2016 at 4:29PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2016 at 6:33AM
On my 75 wagon the turn signals stay locked both up and down, but it doesn't click back off after the turns.  Any ideas??
Edited by gpd294 - 17-November-2016 at 6:37AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2016 at 5:27PM
you mean even if you make a full turn or more then back it don't click off?
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2016 at 10:58PM
Carlos, I think you need that plastic thingy too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2016 at 2:28AM
Yes Johnny. I have to manually disengage the turn signal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2016 at 9:25AM
IIRC there is a small plastic sleeve thing with a cam bump on it that goes on the steering shaft that disengages them... it's missing or the plastic curved ears are broken on the turn signal switch! did it suddenly do this or only after a steering wheel change???
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2016 at 9:28AM
Its been that way ever since I've had it. I need to replace the bulb for the PRD12 indicator so I may just tackle the turn signal issue as well.
Thanks for the help and I'll post my findings once it's done. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2016 at 1:14PM
Shocked "P R D 1 2" Shocked damn dude, somebody screwed up your linkage too ConfusedLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2016 at 3:02AM
LOL! I guess I left N out and screwed up the 2 1 as well....LOL! I meant P R N D 2 1
