  New Posts New Posts RSS Feed - unpost a pic
unpost a pic
Camojoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Camojoe Quote  Post ReplyReply Direct Link To This Post Topic: unpost a pic
    Posted: 21-May-2020 at 9:34AM
I've got the pic posting figgered out, but how do I delete pics?
When I use the edit tab, then photos, the photo links still appear
in the upload window.
I want all the links gone, so I can start fresh.
Regards,
a confused Camojoe
werd tuh yuh momma and dim....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2020 at 10:22AM
open the edit window, highlight (left click hold & sweep) what you want to disappear and hit Backspace
or locate your cursor at the end of what you want to disappear and hit backspace repeatedly,
or hold it down and it'll start traveling right to left like an eraser
Post Options Post Options   Thanks (0) Thanks(0)   Quote Camojoe Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2020 at 11:48AM
Thanks for the tip, but I already tried that, it didn't give the desired results.
If I go back to edit, the links are still there.
I'm thinking it may take an admin to delete the pics, since they may be hosted on an off-site server.
Regards,
Camo
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2020 at 4:50AM
I am not sure what you are asking? Do you want the photos deleted from your post? Or from the file manager with your uploads. You can leave photos in your file manager, even if they are not posted.
