  New Posts New Posts RSS Feed - Upper ball joints
Upper ball joints
Markb73gtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Markb73gtorino Quote  Post ReplyReply Direct Link To This Post Topic: Upper ball joints
    Posted: 20-October-2018 at 11:00AM
Hello all,
Ran into an issue, upper ball joints appear to be riveted in. How do I get them out? There was one nut I could remove but they are still in solid. I will work on the lowers while I wait for an answer. Thanks
Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2018 at 11:05AM
grind the heads of the rivets off! new ones come with bolts and nuts to attach themWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2018 at 11:08AM
oh and you may need to drive them out with a punch and hammer....after the heads are removed
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2018 at 12:05PM
Like John says you can use a hammer and a punch.  Or an air chisel with a punch type head is helpful if you have one to drive the rivets out once you cut the heads off.  Once the rivets are knocked out you can remove it.
